IPFS Gateway Tor Network Bitcoin Node
So I want to run a full node thru IPFS as a gateway and once the blockchain is fully synched use Tor as proxy for my outgoing transactions.
While I believe it to be theatrically possible would hosting the entire block chain have a strenuous effect on the IPFS network?
This article inspired me to attempt this.
You might want to set Reprovider.Strategy to “roots”. Otherwise, you’ll try to advertise every single block.
