I want to develop a nodejs app in which a user stores a file on IPFS and gives the hash to the app.
What I would like to do is to verify that the contents under this given hash produce the same hash, something similar to verifying the checksum.
Is there a way to do it using the ipfs-api module?
For example:
A user writes a “Hello world” string in the “data.txt” file, adds the file on IPFS and gets the hash: QmWpXFXgii2CfYMBXj9jihPcokpFhwCjGQqOipZ1LVGgTU
Then he runs my app with the IPFS hash: node myapp.js QmWpXFXgii2CfYMBXj9jihPcokpFhwCjGQqOipZ1LVGgTU
I would like to verify that the contents under this hash are “Hello world” and he didn’t provide another hash.
Basically I want to read from an IPFS hash and get the contents of the file stored under this address, then I want to verify that the contents of the file produce actually the given hash.
In other words, a user claims that a file with “Hello world” gives this hash: QmWpXFXgii2CfYMBXj9jihPcokpFhwCjGQqOipZ1LVGgTU but when I read under this hash there is another file with “Hello”.
Actually I want to make sure that the hash that the user gives me is what he claims to be.
PS. In ipfs-api npm package I didn’t find an “onlyHash” option…
So it sounds like you want the “only hash” option. You would take the file and then add with onlyHash: true and you’ll get the hash of the file back. Then you can verify if it’s the same.
Though that shouldn’t actually be needed as if you retrieve a file with a certain hash from IPFS it’s guaranteed that the contents hashes to that hash.
If you run jsipfs add --help you’ll see the --only-hash option which maps to onlyHash when you use the module.
