Hi, i’,m trying to implement reward based on hosting file in ipfs.
I’m looked all of API, but can’t find any command, with which i can check if remote node has pinned file or caт provide it.
As i could understand by reading this forum, that findprovs can show info about nodes, but, this list updating ~24 hours, so it’s not solution to the proble.
I Thought about some crypto functions with keys, to prove, but can’t finish this idea.
Pls if someone know about some API or maybe any ideas how can i prove that node has file?
The naïve approach would be to request the hash from the node and check that it sent you the correct content. If you’re looking for a cryptographic method built into IPFS itself where an untrusted peer can prove possession of a hash’s content without just sending the entire hash so you can verify it, I’m 99.99987% sure you’re not going to find something already implemented (and I think this is related to the proof of replication that filecoin is trying to solve, though I don’t know if they’ve figured this out yet).
