Hello everyone, thanks in advance for your time.
I have this electron app where I was previously using js-ipfs but I now I am switching to go-ipfs and ipfsd-ctl.
I manage to connect and the cat function works sometimes and the add function just hangs forever.
Not sure what’s wrong, but this only happens when I export the IPFS node to use it in another file and even in the same file but in a different function.
This worked fine when using ipfs-core, sorry if I am missing something basic I am kind of learning by doing here.
Some code:
import Ctl from "ipfsd-ctl";
//declare the variable in the outer scope
export let ipfsd = null;
// inside the function that initializes electron
ipfsd = await Ctl.createController({
ipfsHttpModule: require("ipfs-http-client"),
type: "go",
ipfsBin: ipfsBin,
ipfsOptions: {
repo,
remote: true,
disposable: false,
test: false,
args: ["--migrate", "--enable-gc", "--routing", "dhtclient"],
await ipfsd.init();
await ipfsd.start();
// If I were to do ipfsd.api.add(someContent) inside this function it would work fine.
// outside the function/ imported in a different file
const fileHash = await ipfsd.api.add({
content: fileContent,
// it doesn't work
Is there a special way to export the ipfsd node that I am missing?
