IPFS nodejs sdk hangs when trying to fetch non existing hash
When I try to fetch a non existing hash, the sdk hangs.
Here’s what my code looks like:
const ipfsAPI = require('ipfs-api');
const api = ipfsAPI('/ip4/127.0.0.1/tcp/5001');
When I try to fetch a valid address using the below code works fine:
api.ls('QmQLXHs7K98JNQdWrBB2cQLJahPhmupbDjRuH1b9ibmwVa')
    .then(response => console.log('File retrieved:', response))
    .catch(error => console.log('Error while retrieveing file:', error));
But when I try to fetch a non existing address, It hangs and doesn’t stop.
sdk.sdk.files.get('QmQLXHs7K98JNQdWrBB2cQLJahPhmupbDjRuH1b9ibmwVV')
    .then(response => console.log(response))
    .catch(err => console.log(err));
I know that the Go-IPFS HTTP gateway has a timeout of 1h for gettingfiles. It can well be that the HTTP API (which is used by the ipfs-api) has the same timeout. After that you would get the error. So the workaround is to abort the operation yourself if it takes too long.
I just tried it locally, it already hangs >1h. @rohitkhatri would you please open a bug at https://github.com/ipfs/go-ipfs ?
I have opened but at github here’s the url: https://github.com/ipfs/go-ipfs/issues/5537
