IPFS peer is getting error when there is single `Bootstrap` peer
Background
The application’s responsibility is to put some database chunks(from PostgreSQL) into the IPFS network; then other nodes can use this data to load into PostgreSQL. It has many benefits as multiple nodes require the same data in the database.
Segment - this is how I call the database chunk; you can see this keyword in my application logs somewhere
The issue
I have an application that is starting the private IPFS network. The network works fine with multiple Bootstrap peers in the configuration.
However when I have only one node(let’s call it A) started. When I add a new node to the network, it has only one bootstrap peer(A). And I am getting the following errors:
I could not reproduce this issue with 2 Bootstrap peers.
What can cause the issue? Is there any requirement to have at least two nodes in the network?
Logs
You can find the ipfs logs here: IPFS logs · GitHub
Second node config
  "Identity": {
    "PeerID": "12D3KooWJpqacxjCYHzbbcoutMAM98TUaDtRgDbvSTtsym72VZRp",
    "PrivKey": "CAESQNWRZsagBeuFhMakswreOSf9TrDzFAEPHPj4DFA4qWGihdgtQuP4uZr1tbFjcbUkEG06SU4avHBClCNqhvoyNE8="
  "Datastore": {
    "StorageMax": "10GB",
    "StorageGCWatermark": 90,
    "GCPeriod": "1h",
    "Spec": {
      "mounts": [
          "child": {
            "path": "blocks",
            "sync": true,
            "type": "flatfs"
          "mountpoint": "/blocks",
          "prefix": "flatfs.datastore",
          "type": "measure"
          "child": {
            "compression": "none",
            "path": "datastore",
            "type": "levelds"
          "mountpoint": "/",
          "type": "measure"
      "type": "mount"
    "HashOnRead": false,
    "BloomFilterSize": 0
  "Addresses": {
    "Swarm": [
      "/ip4/0.0.0.0/tcp/4045",
      "/ip4/0.0.0.0/udp/4045/quic",
      "/ip4/0.0.0.0/udp/4045/quic-v1",
      "/ip4/0.0.0.0/udp/4045/quic-v1/webtransport"
    "Announce": [],
    "AppendAnnounce": [],
    "NoAnnounce": [],
    "Gateway": "/ip4/127.0.0.1/tcp/8080"
  "Mounts": {
    "IPFS": "/ipfs",
    "IPNS": "/ipns",
    "FuseAllowOther": false
  "Discovery": {
    "MDNS": {
      "Enabled": false
  "Routing": {
    "Routers": null,
    "Methods": null
  "Ipns": {
    "RepublishPeriod": "",
    "RecordLifetime": "",
    "ResolveCacheSize": 128
  "Bootstrap": [
    "/ip4/127.0.0.1/tcp/4035/p2p/12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"
  "Gateway": {
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "RootRedirect": "",
    "PathPrefixes": [],
    "APICommands": [],
    "NoFetch": false,
    "NoDNSLink": false,
    "PublicGateways": null
  "API": {
    "HTTPHeaders": {}
  "Swarm": {
    "AddrFilters": null,
    "DisableNatPortMap": false,
    "RelayClient": {},
    "RelayService": {},
    "Transports": {
      "Network": {},
      "Security": {},
      "Multiplexers": {}
    "ConnMgr": {},
    "ResourceMgr": {
      "Limits": {}
  "AutoNAT": {},
  "Pubsub": {
    "Router": "",
    "DisableSigning": false
  "Peering": {
    "Peers": null
  "DNS": {
    "Resolvers": {}
  "Migration": {
    "DownloadSources": [],
    "Keep": ""
  "Provider": {
    "Strategy": ""
  "Reprovider": {},
  "Experimental": {
    "FilestoreEnabled": false,
    "UrlstoreEnabled": false,
    "GraphsyncEnabled": false,
    "P2pHttpProxy": false,
    "StrategicProviding": false,
    "OptimisticProvide": false,
    "OptimisticProvideJobsPoolSize": 0
  "Plugins": {
    "Plugins": null
  "Pinning": {
    "RemoteServices": {}
  "Internal": {}
First node config
  "Identity": {
    "PeerID": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs",
    "PrivKey": "CAESQMDGEBrDqEwtCtNmZC8a2qX1qTI+C5yUZeVw0E5TAmOF9j26wXxaOdOgtS+NoNU9LsAWfBMvH0omq7OYufTBHUo="
  "Datastore": {
    "GCPeriod": "1h",
    "Spec": {
      "mounts": [
          "child": {
            "path": "blocks",
            "sync": true,
            "type": "flatfs"
          "type": "measure"
          "child": {
            "type": "levelds"
          "mountpoint": "/",
          "type": "measure"
      "type": "mount"
  "Addresses": {
    "Swarm": [
      "/ip4/0.0.0.0/tcp/4035",
      "/ip4/0.0.0.0/udp/4035/quic",
      "/ip4/0.0.0.0/udp/4035/quic-v1",
      "/ip4/0.0.0.0/udp/4035/quic-v1/webtransport"
    "Announce": [],
    "NoAnnounce": [],
  "Mounts": {
    "IPFS": "/ipfs",
    "IPNS": "/ipns",
  "Discovery": {
    "MDNS": {
      "Enabled": false
  "Routing": {
    "Routers": null,
    "Methods": null
  "Ipns": {
  "Bootstrap": [
  "Gateway": {
    "HTTPHeaders": {
        "X-Requested-With",
        "Range",
        "User-Agent"
        "GET"
    "RootRedirect": "",
    "PathPrefixes": [],
    "APICommands": [],
    "NoFetch": false,
    "NoDNSLink": false,
  "API": {
    "HTTPHeaders": {}
  "Swarm": {
    "RelayClient": {},
    "RelayService": {},
    "Transports": {
      "Network": {},
      "Security": {},
      "Multiplexers": {}
    "ConnMgr": {},
    "ResourceMgr": {
      "Limits": {}
  "AutoNAT": {},
  "Pubsub": {
    "Router": "",
  "Peering": {
    "Peers": null
  "DNS": {
    "Resolvers": {}
  "Migration": {
    "Keep": ""
  "Provider": {
    "Strategy": ""
  "Reprovider": {},
  "Experimental": {
  "Plugins": {
    "Plugins": null
  "Pinning": {
  "Internal": {}
The logs are following:
Info level
fetching history segment QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg (attempt 1, timeout 10s)
failed to fetch segment: could not get file with CID, connected peer addresses ,/ip4/127.0.0.1/tcp/4035: context deadline exceeded
fetching history segment QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg (attempt 2, timeout 20s)
fetching history segment QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg (attempt 3, timeout 30s)
fetching history segment QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg (attempt 4, timeout 40s)
fetching history segment QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg (attempt 5, timeout 50s)
Debug logs
2023-05-24T14:52:58.496+0200	DEBUG	blockservice	blockservice/blockservice.go:247	BlockService: Searching
2023-05-24T14:52:58.496+0200	DEBUG	bitswap	getter/getter.go:86	Bitswap.GetBlockRequest.Start	{"cid": "QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}
2023-05-24T14:52:58.496+0200	INFO	bs:sess	session/session.go:460	No peers - broadcasting	{"session": 2, "want-count": 1}
2023-05-24T14:52:58.496+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:52:59.496+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:52:59.497+0200	DEBUG	bs:sess	session/session.go:361	FindMorePeers	{"session": 2, "cid": "QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg", "pending": 1}
2023-05-24T14:52:59.497+0200	DEBUG	bitswap	providerquerymanager/providerquerymanager.go:329	New Provider Query on cid: QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg
2023-05-24T14:52:59.497+0200	DEBUG	bitswap	providerquerymanager/providerquerymanager.go:234	Beginning Find Provider Request for cid: QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg
2023-05-24T14:52:59.497+0200	DEBUG	routing/composable	go-libp2p-routing-helpers/compparallel.go:432	getChannelOrErrorParallel: returning channel
2023-05-24T14:52:59.497+0200	DEBUG	routing/composable	go-libp2p-routing-helpers/compparallel.go:332	getChannelOrErrorParallel: starting execution for router &{0xc000e50a80 0xc000e51500} with timeout 0s and ignore errors true
2023-05-24T14:52:59.497+0200	DEBUG	routing/composable	go-libp2p-routing-helpers/compparallel.go:349	getChannelOrErrorParallel: calling router function for router &{0xc000e50a80 0xc000e51500} with timeout 0s and ignore errors true
2023-05-24T14:52:59.497+0200	DEBUG	dht	go-libp2p-kad-dht/routing.go:522	finding providers	{"cid": "QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg", "mh": "bciqcrj47pdzbkfvrif2emmktmckdcw32rbc4t5twtrdhfxm7i64jori"}
2023-05-24T14:52:59.497+0200	DEBUG	routing/composable	go-libp2p-routing-helpers/compparallel.go:375	getChannelOrErrorParallel: getting channel value for router &{0xc000e50a80 0xc000e51500} with timeout 0s and ignore errors true closed channel: true
2023-05-24T14:52:59.497+0200	DEBUG	bitswap	providerquerymanager/providerquerymanager.go:329	Received provider (12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs) for cid (QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg)
2023-05-24T14:52:59.497+0200	DEBUG	bs:sprmgr	sessionpeermanager/sessionpeermanager.go:68	Bitswap: Added peer to session	{"session": 2, "peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "peerCount": 1}
2023-05-24T14:52:59.498+0200	DEBUG	dht	go-libp2p-kad-dht/routing.go:598	1 provider entries
2023-05-24T14:52:59.498+0200	DEBUG	dht	go-libp2p-kad-dht/routing.go:603	got provider: {12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs: [/ip4/172.21.18.199/tcp/4035 /ip4/127.0.0.1/tcp/4035]}
2023-05-24T14:52:59.498+0200	DEBUG	dht	go-libp2p-kad-dht/routing.go:624	got closer peers: 0 []
2023-05-24T14:52:59.498+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:52:59.499+0200	DEBUG	routing/composable	go-libp2p-routing-helpers/compparallel.go:375	getChannelOrErrorParallel: getting channel value for router &{0xc000e50a80 0xc000e51500} with timeout 0s and ignore errors true closed channel: false
2023-05-24T14:52:59.499+0200	DEBUG	routing/composable	go-libp2p-routing-helpers/compparallel.go:415	getChannelOrErrorParallel: finished executing all routers 1
2023-05-24T14:52:59.499+0200	DEBUG	bitswap	providerquerymanager/providerquerymanager.go:329	Finished Provider Query on cid: QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg
2023-05-24T14:53:00.497+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:53:02.498+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:53:03.447+0200	DEBUG	basichost	basic/basic_host.go:338	failed to fetch local IPv6 address	{"error": "no route found for ::"}
2023-05-24T14:53:05.499+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:53:06.198+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.199+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:06.199+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000236542}
2023-05-24T14:53:06.199+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000308787}
2023-05-24T14:53:06.199+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.200+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:06.200+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqmyjikqcn6raxg3qkx7dlng6zzntafamkjkdmw7lm2ewzyq43ozpi"}
2023-05-24T14:53:06.200+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000275405}
2023-05-24T14:53:06.213+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.213+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ=="}
2023-05-24T14:53:06.213+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ==", "time": 0.000297015}
2023-05-24T14:53:06.213+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ==", "time": 0.000354142}
2023-05-24T14:53:06.214+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.214+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ=="}
2023-05-24T14:53:06.214+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqorc35chgaczfdhtdz7nqxiicbdh37nvmp7fatfwa3l3bydz256yi"}
2023-05-24T14:53:06.214+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ==", "time": 0.00018734}
2023-05-24T14:53:06.217+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.218+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:06.218+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000163375}
2023-05-24T14:53:06.218+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.00021965}
2023-05-24T14:53:06.218+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.219+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:06.219+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqmyjikqcn6raxg3qkx7dlng6zzntafamkjkdmw7lm2ewzyq43ozpi"}
2023-05-24T14:53:06.219+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000329205}
2023-05-24T14:53:06.261+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.262+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:06.262+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000254876}
2023-05-24T14:53:06.262+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000304499}
2023-05-24T14:53:06.263+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:06.263+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:06.263+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqmyjikqcn6raxg3qkx7dlng6zzntafamkjkdmw7lm2ewzyq43ozpi"}
2023-05-24T14:53:06.263+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000255428}
2023-05-24T14:53:08.447+0200	DEBUG	basichost	basic/basic_host.go:338	failed to fetch local IPv6 address	{"error": "no route found for ::"}
2023-05-24T14:53:09.500+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:53:11.179+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.179+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "ACQIARIg9j26wXxaOdOgtS+NoNU9LsAWfBMvH0omq7OYufTBHUo="}
2023-05-24T14:53:11.179+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "ACQIARIg9j26wXxaOdOgtS+NoNU9LsAWfBMvH0omq7OYufTBHUo=", "time": 0.000268152}
2023-05-24T14:53:11.179+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "ACQIARIg9j26wXxaOdOgtS+NoNU9LsAWfBMvH0omq7OYufTBHUo=", "time": 0.000297817}
2023-05-24T14:53:11.180+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.180+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiAop5948hUWsUF0RjFTYJQxW3qIRcn2dpxGct2fR7iXRQ=="}
2023-05-24T14:53:11.180+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiAop5948hUWsUF0RjFTYJQxW3qIRcn2dpxGct2fR7iXRQ==", "time": 0.000212498}
2023-05-24T14:53:11.180+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiAop5948hUWsUF0RjFTYJQxW3qIRcn2dpxGct2fR7iXRQ==", "time": 0.000259275}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiAop5948hUWsUF0RjFTYJQxW3qIRcn2dpxGct2fR7iXRQ=="}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqcrj47pdzbkfvrif2emmktmckdcw32rbc4t5twtrdhfxm7i64jori"}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiAop5948hUWsUF0RjFTYJQxW3qIRcn2dpxGct2fR7iXRQ==", "time": 0.000376274}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000095097}
2023-05-24T14:53:11.181+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000104405}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ=="}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqmyjikqcn6raxg3qkx7dlng6zzntafamkjkdmw7lm2ewzyq43ozpi"}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDMJQqAm+iC5twVf41tN7OWzAUDFJUNlvrZols4hzbsvQ==", "time": 0.000197319}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiBZlIQ5Bl8pYZ70EoDLuTK+UsVtmcWWa2XgERI58Ji77w=="}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiBZlIQ5Bl8pYZ70EoDLuTK+UsVtmcWWa2XgERI58Ji77w==", "time": 0.000115275}
2023-05-24T14:53:11.182+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiBZlIQ5Bl8pYZ70EoDLuTK+UsVtmcWWa2XgERI58Ji77w==", "time": 0.00014991}
2023-05-24T14:53:11.183+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.183+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiBZlIQ5Bl8pYZ70EoDLuTK+UsVtmcWWa2XgERI58Ji77w=="}
2023-05-24T14:53:11.183+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqftfeehedf6klbt32bfaglxezl4uwfnwm4lftlmxqbcerz6cmlx3y"}
2023-05-24T14:53:11.184+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiBZlIQ5Bl8pYZ70EoDLuTK+UsVtmcWWa2XgERI58Ji77w==", "time": 0.00031029}
2023-05-24T14:53:11.184+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.184+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiAkPN2XsrdVYZuKIMRNPrTJnN2m3ORc6AYw9UEtHL4usA=="}
2023-05-24T14:53:11.184+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiAkPN2XsrdVYZuKIMRNPrTJnN2m3ORc6AYw9UEtHL4usA==", "time": 0.000161262}
2023-05-24T14:53:11.184+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiAkPN2XsrdVYZuKIMRNPrTJnN2m3ORc6AYw9UEtHL4usA==", "time": 0.000198732}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiAkPN2XsrdVYZuKIMRNPrTJnN2m3ORc6AYw9UEtHL4usA=="}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqcipg5s6zlovlbtofcbrcnh22mthg5u3ooixhiayypkqjnds7c5ma"}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiAkPN2XsrdVYZuKIMRNPrTJnN2m3ORc6AYw9UEtHL4usA==", "time": 0.000228748}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ=="}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ==", "time": 0.000148257}
2023-05-24T14:53:11.185+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ==", "time": 0.0001819}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ=="}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqorc35chgaczfdhtdz7nqxiicbdh37nvmp7fatfwa3l3bydz256yi"}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDoi30RzAFkozzHn7YXQgQRn39tWP+UEy2Btew4HnXfYQ==", "time": 0.000217346}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDLwfQ4s2NxvxQJZVLrRpeSdtoOvxw+GCoz5XWwv9x9LQ=="}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDLwfQ4s2NxvxQJZVLrRpeSdtoOvxw+GCoz5XWwv9x9LQ==", "time": 0.000153265}
2023-05-24T14:53:11.186+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiDLwfQ4s2NxvxQJZVLrRpeSdtoOvxw+GCoz5XWwv9x9LQ==", "time": 0.000208499}
2023-05-24T14:53:11.187+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.187+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDLwfQ4s2NxvxQJZVLrRpeSdtoOvxw+GCoz5XWwv9x9LQ=="}
2023-05-24T14:53:11.187+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqmxqpuhczwg4n7cqewkuxli2lze5w2b27rypqyfiz6k5nqx7oh2li"}
2023-05-24T14:53:11.187+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiDLwfQ4s2NxvxQJZVLrRpeSdtoOvxw+GCoz5XWwv9x9LQ==", "time": 0.000237554}
2023-05-24T14:53:11.188+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiCURbMmqidfjKplKLEEAoLL/EU9MDmZGJERhFnkRDQsYA=="}
2023-05-24T14:53:11.188+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiCURbMmqidfjKplKLEEAoLL/EU9MDmZGJERhFnkRDQsYA==", "time": 0.000193352}
2023-05-24T14:53:11.188+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:159	responded to message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 4, "key": "EiCURbMmqidfjKplKLEEAoLL/EU9MDmZGJERhFnkRDQsYA==", "time": 0.000236422}
2023-05-24T14:53:11.189+0200	DEBUG	dht	go-libp2p-kad-dht/dht.go:671	peer found	{"peer": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs"}
2023-05-24T14:53:11.189+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:116	handling message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiCURbMmqidfjKplKLEEAoLL/EU9MDmZGJERhFnkRDQsYA=="}
2023-05-24T14:53:11.189+0200	DEBUG	dht	go-libp2p-kad-dht/handlers.go:345	adding provider	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "key": "bciqjirnte2vcox4mvjssrmieakbmx7cfhuydtgiyseiyiwpeiq2cyya"}
2023-05-24T14:53:11.189+0200	DEBUG	dht	go-libp2p-kad-dht/dht_net.go:133	handled message	{"from": "12D3KooWSPb4DqHiUTtNP59AMu4Q4L2yW13iNTsV35TqXx1pZUfs", "type": 2, "key": "EiCURbMmqidfjKplKLEEAoLL/EU9MDmZGJERhFnkRDQsYA==", "time": 0.000265626}
2023-05-24T14:53:13.447+0200	DEBUG	basichost	basic/basic_host.go:338	failed to fetch local IPv6 address	{"error": "no route found for ::"}
2023-05-24T14:53:13.477+0200	DEBUG	bootstrap	bootstrap/bootstrap.go:142	12D3KooWJpqacxjCYHzbbcoutMAM98TUaDtRgDbvSTtsym72VZRp no more bootstrap peers to create 3 connections
2023-05-24T14:53:13.477+0200	DEBUG	bootstrap	bootstrap/bootstrap.go:90	12D3KooWJpqacxjCYHzbbcoutMAM98TUaDtRgDbvSTtsym72VZRp bootstrap error: not enough bootstrap peers to bootstrap
2023-05-24T14:53:14.501+0200	DEBUG	bs:sess	session/session.go:467	broadcastWantHaves	{"session": 2, "cids": [{"/":"QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}]}
2023-05-24T14:53:18.448+0200	DEBUG	basichost	basic/basic_host.go:338	failed to fetch local IPv6 address	{"error": "no route found for ::"}
2023-05-24T14:53:18.497+0200	DEBUG	blockservice	blockservice/blockservice.go:247	BlockService: Searching
2023-05-24T14:53:18.497+0200	DEBUG	bitswap	getter/getter.go:86	Bitswap.GetBlockRequest.Start	{"cid": "QmR5MGGSBpSXbh5v71ru5tys8Rvd2uX7ybeAwpbMxZztSg"}
The error you’re talking about is the one related to “could not get file with CID”? Is the node working as expected otherwise?
