$50 bounty for help to setup our node
I have installed go-ipfs on our ubuntu server.
I’ve tried many different configs, however we never connect to any other peers
So ‘ipfs swarm peers’ always returns nothing.
I’m clueless at this point a I would like to offer $50 for an expert to help us out.
Thank you in advance!!!
The default installation of go-ipfs should have several Internet accessible bootstrap nodes. If those nodes are not reachable, then you’re most likely behind some sort of firewall or a CG-NAT.
Please fill in a few details about your Internet connection and/or your desired IPFS network.
I’m not sure if a paid bounty is appropriate or necessary for this forum.
Here’s a working docker-compose. Note that the port 4001 is the one that must also be opened up on your router/firewall, so the public internet can connect to that port on your machine.
More info:
Ubuntu 20.04.3 LTS
go-ipfs 0.4.17
We rent a server in a data center, so I’m not sure if CG-NAT can be a problem.
Port 4001/tcp is open for both IPV4 and IPV6.
Our IP is 135.181.176.108
nc 135.181.176.108 4001 returns
/multistream/1.0.0
When I run ipfs log tail, I’ll get this result:
“event”:“Bitswap.Rebroadcast.active”,“session”:“d2dbf471-868b-4f6c-9e84-3805afffbf51”,“system”:“bitswap”,“time”:“2021-11-09T07:55:04.412007043Z”}
{“event”:“Bitswap.Rebroadcast.idle”,“session”:“d2dbf471-868b-4f6c-9e84-3805afffbf51”,“system”:“bitswap”,“time”:“2021-11-09T07:55:04.41204256Z”}
{“event”:“Bitswap.Rebroadcast.idle”,“session”:“d2dbf471-868b-4f6c-9e84-3805afffbf51”,“system”:“bitswap”,“time”:“2021-11-09T07:55:04.412068549Z”}
{“TraceID”:3365091883068573247,“SpanID”:228329550610211072,“ParentSpanID”:0,“Operation”:“FindPeer”,“Start”:“2021-11-09T08:55:04.412792352+01:00”,“Duration”:28704,“Tags”:{“system”:“dht”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.412809314+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmYzwtS8cy5efUbqzMWppMHVn3Zit2BNZ23d1WsyyntC3V”}]},{“Timestamp”:“2021-11-09T08:55:04.412819813+01:00”,“Fields”:[{“Key”:“error”,“Value”:“failed to find any peer in table”}]}]}
{“TraceID”:1753378649603088934,“SpanID”:6410319792423290936,“ParentSpanID”:0,“Operation”:“FindPeer”,“Start”:“2021-11-09T08:55:04.413038184+01:00”,“Duration”:11322,“Tags”:{“system”:“dht”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413043985+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.413048894+01:00”,“Fields”:[{“Key”:“error”,“Value”:“failed to find any peer in table”}]}]}
{“TraceID”:7178030771370860967,“SpanID”:672485672629064406,“ParentSpanID”:0,“Operation”:“dhtRunBootstrap”,“Start”:“2021-11-09T08:55:04.412766553+01:00”,“Duration”:297129,“Tags”:{“system”:“dht”},“Logs”:}
{“addresses”:["/p2p-circuit/ipfs/QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J","/ip4/127.0.0.1/tcp/4001","/ip4/135.181.176.108/tcp/4001","/ip6/::1/tcp/4001","/ip6/2a01:4f9:3a:1e53::2/tcp/4001"],“event”:“interfaceListenAddresses”,“system”:“addrutil”,“time”:“2021-11-09T07:55:04.413690673Z”}
{“addresses”:["/ip4/127.0.0.1/tcp/4001","/ip4/135.181.176.108/tcp/4001","/ip6/::1/tcp/4001","/ip6/2a01:4f9:3a:1e53::2/tcp/4001","/p2p-circuit/ipfs/QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J"],“event”:“interfaceListenAddresses”,“system”:“addrutil”,“time”:“2021-11-09T07:55:04.41418328Z”}
{“TraceID”:224899370432576246,“SpanID”:3565762185862035753,“ParentSpanID”:0,“Operation”:“swarmDialDo”,“Start”:“2021-11-09T08:55:04.413798205+01:00”,“Duration”:442383,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413804737+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:04.413805469+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.41380625+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”}]}]}
{“event”:“swarmDialBackoffAdd”,“localPeer”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“remotePeer”:“QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”,“subsystem”:“swarm”,“system”:“swarm2”,“time”:“2021-11-09T07:55:04.414272348Z”}
{“TraceID”:2945728189716846729,“SpanID”:2775462494564824908,“ParentSpanID”:0,“Operation”:“swarmDialAttemptStart”,“Start”:“2021-11-09T08:55:04.413781423+01:00”,“Duration”:503769,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413794749+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.41379561+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”}]},{“Timestamp”:“2021-11-09T08:55:04.413796472+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]}]}
{“TraceID”:2600057042939071408,“SpanID”:2354401287681785405,“ParentSpanID”:0,“Operation”:“swarmDialAttemptSync”,“Start”:“2021-11-09T08:55:04.413760775+01:00”,“Duration”:543533,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413766826+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”}]}]}
{“event”:“bootstrapDialFailed”,“peerID”:“QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”,“system”:“core”,“time”:“2021-11-09T07:55:04.414322642Z”}
{“TraceID”:1402349623034683027,“SpanID”:4750472383538571605,“ParentSpanID”:0,“Operation”:“bootstrapDial”,“Start”:“2021-11-09T08:55:04.413031402+01:00”,“Duration”:1298003,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413044797+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.413049496+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt”}]}]}
{“addresses”:["/p2p-circuit/ipfs/QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J","/ip4/127.0.0.1/tcp/4001","/ip4/135.181.176.108/tcp/4001","/ip6/::1/tcp/4001","/ip6/2a01:4f9:3a:1e53::2/tcp/4001"],“event”:“interfaceListenAddresses”,“system”:“addrutil”,“time”:“2021-11-09T07:55:04.414432279Z”}
{“TraceID”:3477061722810302665,“SpanID”:6507655186811103757,“ParentSpanID”:0,“Operation”:“swarmDialDo”,“Start”:“2021-11-09T08:55:04.41397087+01:00”,“Duration”:518707,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413979316+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:04.413980378+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.41398148+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”}]}]}
{“event”:“swarmDialBackoffAdd”,“localPeer”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“remotePeer”:“QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”,“subsystem”:“swarm”,“system”:“swarm2”,“time”:“2021-11-09T07:55:04.414522749Z”}
{“TraceID”:8593057693163018440,“SpanID”:5504296102487837969,“ParentSpanID”:0,“Operation”:“swarmDialAttemptStart”,“Start”:“2021-11-09T08:55:04.413953437+01:00”,“Duration”:586985,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413966953+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:04.413967804+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.413968636+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”}]}]}
{“TraceID”:6228950745398945327,“SpanID”:5851450306830460201,“ParentSpanID”:0,“Operation”:“swarmDialAttemptSync”,“Start”:“2021-11-09T08:55:04.413927528+01:00”,“Duration”:631388,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413936315+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”}]}]}
{“event”:“bootstrapDialFailed”,“peerID”:“QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”,“system”:“core”,“time”:“2021-11-09T07:55:04.414572893Z”}
{“TraceID”:8523483481538180493,“SpanID”:7050246832198516198,“ParentSpanID”:0,“Operation”:“bootstrapDial”,“Start”:“2021-11-09T08:55:04.413043815+01:00”,“Duration”:1536152,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413059274+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.413063732+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa”}]}]}
{“TraceID”:5873077715542676165,“SpanID”:5308367098315301317,“ParentSpanID”:0,“Operation”:“swarmDialDo”,“Start”:“2021-11-09T08:55:04.413218023+01:00”,“Duration”:5003426729,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413228422+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:04.413229384+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.413230296+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”}]}]}
{“event”:“swarmDialBackoffAdd”,“localPeer”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“remotePeer”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”,“subsystem”:“swarm”,“system”:“swarm2”,“time”:“2021-11-09T07:55:09.416698242Z”}
{“TraceID”:7372871456966159925,“SpanID”:5714571752065973988,“ParentSpanID”:0,“Operation”:“swarmDialAttemptStart”,“Start”:“2021-11-09T08:55:04.413183839+01:00”,“Duration”:5003528941,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413209607+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”}]},{“Timestamp”:“2021-11-09T08:55:04.41321118+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:04.413212462+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
{“TraceID”:918721501841676843,“SpanID”:2122405287170964323,“ParentSpanID”:0,“Operation”:“swarmDialAttemptSync”,“Start”:“2021-11-09T08:55:04.413160104+01:00”,“Duration”:5003575208,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413164993+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”}]}]}
{“event”:“bootstrapDialFailed”,“peerID”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”,“system”:“core”,“time”:“2021-11-09T07:55:09.416751162Z”}
{“TraceID”:5099296432070528259,“SpanID”:191742056011874146,“ParentSpanID”:0,“Operation”:“bootstrapDial”,“Start”:“2021-11-09T08:55:04.413039427+01:00”,“Duration”:5003720502,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413057431+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:04.413061608+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”}]}]}
{“TraceID”:351142641020587811,“SpanID”:7390493861614208541,“ParentSpanID”:0,“Operation”:“bootstrapStart”,“Start”:“2021-11-09T08:55:04.413008198+01:00”,“Duration”:5003768652,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.413014329+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
{“error”:“failed to bootstrap. dial attempt failed: \u003cpeer.ID QfCNr4\u003e --\u003e \u003cpeer.ID SoLPpp\u003e dial attempt failed: context deadline exceeded”,“event”:“bootstrapError”,“peerID”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“system”:“core”,“time”:“2021-11-09T07:55:09.416795295Z”}
{“TraceID”:1214095155593255250,“SpanID”:459125204005785017,“ParentSpanID”:0,“Operation”:“periodicBootstrap”,“Start”:“2021-11-09T08:55:04.412766473+01:00”,“Duration”:5004037959,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:04.412790518+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
{“event”:“Bitswap.Rebroadcast.idle”,“session”:“d2dbf471-868b-4f6c-9e84-3805afffbf51”,“system”:“bitswap”,“time”:“2021-11-09T07:55:14.412009143Z”}
{“event”:“Bitswap.Rebroadcast.idle”,“session”:“d2dbf471-868b-4f6c-9e84-3805afffbf51”,“system”:“bitswap”,“time”:“2021-11-09T07:55:24.412002384Z”}
{“event”:“Bitswap.Rebroadcast.idle”,“session”:“d2dbf471-868b-4f6c-9e84-3805afffbf51”,“system”:“bitswap”,“time”:“2021-11-09T07:55:34.411998168Z”}
{“event”:“swarmDialBackoff”,“peerID”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”,“system”:“swarm2”,“time”:“2021-11-09T07:55:34.413112796Z”}
{“TraceID”:5256631057971541753,“SpanID”:2856884024611073453,“ParentSpanID”:0,“Operation”:“swarmDialAttemptSync”,“Start”:“2021-11-09T08:55:34.41309915+01:00”,“Duration”:30117,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413104861+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”}]}]}
{“event”:“bootstrapDialFailed”,“peerID”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”,“system”:“core”,“time”:“2021-11-09T07:55:34.413169703Z”}
{“TraceID”:965083156221112208,“SpanID”:8867900118221190042,“ParentSpanID”:0,“Operation”:“bootstrapDial”,“Start”:“2021-11-09T08:55:34.413048234+01:00”,“Duration”:130356,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413061028+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:34.413065677+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM”}]}]}
{“addresses”:["/p2p-circuit/ipfs/QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J","/ip4/127.0.0.1/tcp/4001","/ip4/135.181.176.108/tcp/4001","/ip6/::1/tcp/4001","/ip6/2a01:4f9:3a:1e53::2/tcp/4001"],“event”:“interfaceListenAddresses”,“system”:“addrutil”,“time”:“2021-11-09T07:55:34.413570016Z”}
{“addresses”:["/p2p-circuit/ipfs/QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J","/ip4/127.0.0.1/tcp/4001","/ip4/135.181.176.108/tcp/4001","/ip6/::1/tcp/4001","/ip6/2a01:4f9:3a:1e53::2/tcp/4001"],“event”:“interfaceListenAddresses”,“system”:“addrutil”,“time”:“2021-11-09T07:55:34.414247532Z”}
{“TraceID”:8847799767487976320,“SpanID”:764382895937503464,“ParentSpanID”:0,“Operation”:“swarmDialDo”,“Start”:“2021-11-09T08:55:34.413879338+01:00”,“Duration”:419088,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413886332+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:34.413887113+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:34.413887965+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”}]}]}
{“event”:“swarmDialBackoffAdd”,“localPeer”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“remotePeer”:“QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”,“subsystem”:“swarm”,“system”:“swarm2”,“time”:“2021-11-09T07:55:34.414332251Z”}
{“TraceID”:1025132399789611418,“SpanID”:5068209933186443515,“ParentSpanID”:0,“Operation”:“swarmDialAttemptStart”,“Start”:“2021-11-09T08:55:34.413859902+01:00”,“Duration”:485444,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413875892+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”}]},{“Timestamp”:“2021-11-09T08:55:34.413876814+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:34.413877675+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
{“TraceID”:7619544336227024715,“SpanID”:9221790151732406984,“ParentSpanID”:0,“Operation”:“swarmDialAttemptSync”,“Start”:“2021-11-09T08:55:34.41383218+01:00”,“Duration”:531029,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413839093+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”}]}]}
{“event”:“bootstrapDialFailed”,“peerID”:“QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”,“system”:“core”,“time”:“2021-11-09T07:55:34.414376735Z”}
{“TraceID”:8348255479990412834,“SpanID”:4125873538260028960,“ParentSpanID”:0,“Operation”:“bootstrapDial”,“Start”:“2021-11-09T08:55:34.413052572+01:00”,“Duration”:1330334,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413067711+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:34.413071979+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb”}]}]}
{“TraceID”:7270439691424275083,“SpanID”:6633847829313700039,“ParentSpanID”:0,“Operation”:“swarmDialDo”,“Start”:“2021-11-09T08:55:34.413153953+01:00”,“Duration”:653817299,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413160826+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:34.413161597+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:34.413162349+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”}]}]}
{“event”:“swarmDialBackoffAdd”,“localPeer”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“remotePeer”:“QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”,“subsystem”:“swarm”,“system”:“swarm2”,“time”:“2021-11-09T07:55:35.067027548Z”}
{“TraceID”:2157007664448639113,“SpanID”:7621580313146610676,“ParentSpanID”:0,“Operation”:“swarmDialAttemptStart”,“Start”:“2021-11-09T08:55:34.413137031+01:00”,“Duration”:653908892,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413150096+01:00”,“Fields”:[{“Key”:“remotePeer”,“Value”:“QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”}]},{“Timestamp”:“2021-11-09T08:55:34.413151078+01:00”,“Fields”:[{“Key”:“subsystem”,“Value”:“swarm”}]},{“Timestamp”:“2021-11-09T08:55:34.413152009+01:00”,“Fields”:[{“Key”:“localPeer”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
{“TraceID”:5220839136595688056,“SpanID”:8046425598755063561,“ParentSpanID”:0,“Operation”:“swarmDialAttemptSync”,“Start”:“2021-11-09T08:55:34.413115541+01:00”,“Duration”:653951161,“Tags”:{“system”:“swarm2”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413120089+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”}]}]}
{“event”:“bootstrapDialFailed”,“peerID”:“QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”,“system”:“core”,“time”:“2021-11-09T07:55:35.067085427Z”}
{“TraceID”:7786614120256053929,“SpanID”:1329057344092450076,“ParentSpanID”:0,“Operation”:“bootstrapDial”,“Start”:“2021-11-09T08:55:34.413062711+01:00”,“Duration”:654032824,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413079032+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]},{“Timestamp”:“2021-11-09T08:55:34.4130834+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ”}]}]}
{“TraceID”:6328359726193304278,“SpanID”:2042956004461713794,“ParentSpanID”:0,“Operation”:“bootstrapStart”,“Start”:“2021-11-09T08:55:34.413023267+01:00”,“Duration”:654096444,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.413028427+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
{“error”:“failed to bootstrap. dial attempt failed: \u003cpeer.ID QfCNr4\u003e --\u003e \u003cpeer.ID aCpDMG\u003e dial attempt failed: protocol not supported”,“event”:“bootstrapError”,“peerID”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”,“system”:“core”,“time”:“2021-11-09T07:55:35.067144207Z”}
{“TraceID”:1027871423615071184,“SpanID”:3157147305361948254,“ParentSpanID”:0,“Operation”:“periodicBootstrap”,“Start”:“2021-11-09T08:55:34.412782414+01:00”,“Duration”:654375069,“Tags”:{“system”:“core”},“Logs”:[{“Timestamp”:“2021-11-09T08:55:34.412806259+01:00”,“Fields”:[{“Key”:“peerID”,“Value”:“QmQfCNr4X8oT6c6QhsVUNLysU18bHb3dygnCk4tS732K5J”}]}]}
Ok, in the end I saw I was running an old version of IPFS.
Updated to 0.10 and now ipfs swarm peers shows a ton of peers!!
Thanks all for the help :slight_smile:
