Docker Go-IPFS & IPFS-Cluster
I’m trying to setup a cluster with multiple peers locally using Docker and I don’t know how to connect each pair of IPFS daemon & IPFS cluster daemon.
This thread seems obsolete since “The container does not run go-ipfs. You should run the IPFS daemon separetly, for example, using the ipfs/go-ipfs Docker container.”
Can anyone give me some hints on what I have to do?
Thanks.
Hi, there are some docs here: https://cluster.ipfs.io/documentation/deployment/#deployment-using-docker .
Let us know how it goes.
Eventually I switched to EC2 instances + Private swarm and works ok.
Thanks for the hint!
