[SOLVED] Need help to setup a new IPFS cluster with 2 peers
[Moderator’s note: the information in this post regarding IPFS Cluster is outdated. Head over to https://cluster.ipfs.io for updated documentation]
Hi.
I wanted to create an IPFS cluster using Docker. Here is what I did.
  1. Just pulled the 2 Docker images
    docker pull ipfs/ipfs-cluster
    docker pull ipfs/go-ipfs
  2. Create a docker compose file:
    version: ‘3’
    services:
    cluster:
    image: ipfs/ipfs-cluster
    ports:
    - 8080:8080
    - 4001:4001
    - 5001:5001
    volumes:
    - ./cluster/config:/data/ipfs-cluster
    peer_a:
    image: ipfs/go-ipfs
    ports:
    - 8081:8080
    - 4002:4001
    - 127.0.0.1:5002:5001
    peer_b:
    image: ipfs/go-ipfs
    ports:
    - 8082:8080
    - 4003:4001
    - 127.0.0.1:5003:5001
  3. Start all my containers. Everything looks fine. When I checked my 2 peers, I get that for my first peer:
    peer identity: QmaFoihnHq3BM8XMtchnjjtpAW3Fh3X2G4X12d8Hp5xStW
And that for my second peer:
peer identity: QmS5SCyyj44KcUouga1QQ5amRQ4VLUVzVLRc2vXQaDBh9f
  1. Then, I login to my cluster container and I want to add my peers. To be sure to have the right address, first, I do:
    ipfs swarm peers | grep QmaFoihnHq3BM8XMtchnjjtpAW3Fh3X2G4X12d8Hp5xStW
And I get:
/ip4/172.26.0.2/tcp/4001/ipfs/QmaFoihnHq3BM8XMtchnjjtpAW3Fh3X2G4X12d8Hp5xStW
So, I try to run the following command:
ipfs-cluster-ctl --debug peers add /ip4/172.26.0.2/tcp/4001/ipfs/QmaFoihnHq3BM8XMtchnjjtpAW3Fh3X2G4X12d8Hp5xStW
But I get the following error:
12:36:53.780 DEBUG cluster-ct: POST: http://127.0.0.1:9094/peers main.go:444
12:37:03.785 DEBUG cluster-ct: Response body: {"code":500,"message":"dial attempt failed: \u003cpeer.ID cqpaEy\u003e --\u003e \u003cpeer.ID aFoihn\u003e dial attempt failed: connection refused"}
 main.go:461
An error ocurred:
  Code: 500
  Message: dial attempt failed: <peer.ID cqpaEy> --> <peer.ID aFoihn> dial attempt failed: connection refused
If I retry, I get the following error:
12:39:25.402 DEBUG cluster-ct: POST: http://127.0.0.1:9094/peers main.go:444
12:39:25.404 DEBUG cluster-ct: Response body: {"code":500,"message":"dial backoff"}
 main.go:461
An error ocurred:
  Code: 500
  Message: dial backoff
I don’t see what I’m doing wrong :confused:
Thanks for your help
Hey @bchevallereau,
I see a number of misunderstandings…
  • The ipfs/ipfs-cluster docker container runs both the ipfs and the ipfs-cluster peers on the same container.
  • The ipfs Peer ID is completely different from the ipfs-cluster peer ID. ipfs swarm peers will not list ipfs-cluster peers.
  • ipfs-cluster-ctl --debug peers add takes an ipfs-cluster peer multiaddress. By default this will be a /9096/ as that is the port in which the cluster peer listens.
  • Note that by default by launching two separate containers both ipfs-cluster peers will be initialized with different cluster_secret and will not be able to talk to each other. I recommend mounting the configuration (/data/ipfs-cluster folder, including service.json) from the outside, setting at least the same secret in both (or leaving it empty). Alternatively you could set the CLUSTER_SECRET environment variable with the same value for both containers, for example CLUSTER_SECRET=c5c7199d2b3bf59a6369c249982fcf309285bdecd79396af6838dbd489d9e019 (32 byte hex-encoded secret). That should make sure that they are initialized with the same secret.
Hope it helps!
Hi
First, thanks a lot for your answer. Yes, I noticed that the ipfs/ipfs-cluster docker container runs both. But I wanted to add more peers. So it’s why I created the other containers.
And it was one of my question. I didn’t know if i should create multiple ipfs/ipfs-cluster or add more ipfs/go-ipfs containers if I wanted multiple peers. If I understand your reply, I should definitely create multiple ipfs/ipfs-cluster containers.
Thanks again
Yeah that’s right, one cluster peer per ipfs peer.
Thanks, it works perfectly well now. Just created 2 containes with this docker compose file:
version: '3'
services:
  peer-1:
    ports:
      - 8080:8080
      - 4001:4001
      - 5001:5001
    volumes:
      - ./cluster/peer-1/config:/data/ipfs-cluster
  peer-2:
    ports:
      - 8081:8080
      - 4002:4001
      - 5002:5001
    volumes:
      - ./cluster/peer-2/config:/data/ipfs-cluster
And then updated th service.json file to have the same value in the field cluster_secret . And then, I added my peer like that:
ipfs-cluster-ctl peers add /ip4/172.26.0.3/tcp/9096/ipfs/QmcLEdDDZ36vBeHnoHV3uDPd7z8Bt2PfPLBgYhMwWqu579
And it works perfectly well!
Thanks
hi, now igot a cluster problem on windows7 when a run “ipfs-cluster-ctl peers add” it return “No help topic for ‘add’”
Hi, I’m going to lock this topic as it is old and instructions here might be misleading. For docs on cluster, head over to https://cluster.ipfs.io/documentation.
