Hello, i am setting up an ipfs cluster, initially between two remote machines, using docker.
I have added the multiaddress of 2nd cluster peer in service.json config of 1st cluster peer like so:
“peer_addresses”: [“/ip4/143.176.14.172/tcp/9096/p2p/12D3KooWHG4PcH53t4zjKFfo1nu4a1UhCvKKm7tTeLJddjBDXKtv”]
Yet, it is not connecting. After multiple restarts, the peerstore file remains empty. Viewing the logs it seems it is not even trying to connect to anything other than its ipfs buddy.
2024-10-04T08:57:32.509Z INFO cluster ipfs-cluster/cluster.go:737 - No other peers
what am i missing here?
Update: changing permissions on peerstore helps me to get that filled, but it is still not trying to connect.
Update2: logs do signal this:
Changing user to ipfs
/usr/local/bin/entrypoint.sh: line 13: su-exec: not found
running one cluster/ipfs pair on each machine and opening 9996 ports. That didnt work somehow.
this morning i went back to original example with a setup of 3 peers on one machine and it works fine. I noticed how multiaddresses in peerstore changed from localhost to a private ip in my lan, so i assume that there is a connection check before addresses are added to peerstore. Meaning connection issues could have been interfering with filling peerstore and not necessarily permission errors.
btw, the cluster path was not the issue in my faulty setup , looking at these logs:
ipfs-cluster-service version 1.0.6+gitd4484ec3f1fb559675555debf1bb9ac3220ad1af
Found IPFS cluster configuration at /data/ipfs-cluster
Hemingway, i am going to give it a fresh try later this morning …
P.S. Good news. It works. Today is smooth sailing. My guess is now (again) that i somehow screwed up when adapting the location of volumes (and creating the local folders with my regular user, not ipfs )
