Is there some info that explains network traffic on IPFS? It seems to use a lot of bandwidth.
Thanks.
Thanks.
Here’s the environment settings for my docker GO-IPFS:
environment:
# Notes:
# Enabling the "lowpower" profile should help. That will disable background data reproviding, set really
# low connection manager limits, and put your node into dhtclient mode.
routing: "dhtclient"
IPFS_PROFILE: "server"
As you can see I set “server” profile myself but apparently “lowpower” is the profile for least resource consumption.
Thanks. How do you install go-ipfs? I had a look around, but it’s confusing. Thanks.
I use docker. Here’s my docker-compose file:
That app uses the HTTP API (from Java) to control IPFS, and so the IPFS gateway itself isn’t exposed to the network, but only visible inside the private docker network. I should cleanup some of the comments in that file so I look less dumb. lol.
If you get IPFS Desktop, it comes with a go-ipfs node
. Might be a bit easier to manage.
