Curious, what is the total number of nodes running IPFS?
How many transactions per day roughly, overall?
- Is there an IPFS explorer?
Thanks.
Thanks.
About the âmain networkâ, there is no centralised place to check (yet), so itâs a hard question:
The IPFS may have an estimate since there are running very popular nodes (Bootstrap nodes, Preload Nodes, Relay Nodes, Gateway Crawler, etc.)
Plus, IPFS nodes can be used to function in a private network (only talking to nodes in the same private network), or in a local network so itâs hard to count them in any way.
There is no âtransactionâ per se, because IPFS is not a blockchain or a marketplace. Itâs a network of nodes storing and exchanging data.
There is a curently-building blockchain on top of IPFS that will provide incentive for that: Filecoin.
There is no âExplorerâ as in âEthereum Explorerâ because there is no consensus on a common âlist of files availableâ (or any common âbig fileâ shared by everyone, such as a ledger in the blockchain world).
There could be a search-engine like Google and some others did for the Web, but they are still very WIP or rudimentary.
Exemple: ipfs-search.com , https://www.ipse.io
Thanks. IPFS search is interesting.
Number of nodes that touched IPFS at 120K seems a bit high? Is there online proof of any sort by any chance?
What would constitute a definitive proof? 120k is an estimate from a core developer. You either have to trust him or explore the network yourself.
It would be good if Juan or others corroborated that number.
Canât just take a number like that.
The source is:
The post is written by Stephen Allen (AKA Stebalien), who is a core developer working full-time for Protocol Labs on Go IPFS and libp2p.
If you trust him:
-On the optimistic side
-On the pessimistic side
Maybe you can reach out to Pinata.cloud , which should have a good view on the network because they try to be connected to a lot of peers to provide a fast âlayer 2 networkâ as they call it (see blog). If you do, Iâm sure reporting back here will be beneficial for a lot of people. ![]()
Can you give examples of sources you would deem acceptable?
@wmougayar The network have kept growing to a few hundreds of thousands, apparently (watch after 1 min):
