Ipfs上应用的问题,为什么ipfs的应用那么少
ipfs运行也有很长一段时间了,为什么至今还是没有出来用户量比较多的应用
IPFS is still very young and under active development. For js-ipfs in particular, it’s still in alpha so it’s unlikely that there will be widespread adoption of it until it’s more functionally complete and stable for developers.
In spite of this, there are already some developers making apps on top of or that use IPFS.
感谢您的回复,我有个疑问,为什么你能回复我的帖子,我来自中国,用的是中文,你看到的也是中文吗,还是英文的?
I see Chinese, but I translated it to English using Google translate.
辛苦您了!问一下,你是ipfs社区官方人员还是ipfs的爱好者
I’m just a fan of IPFS.
你为什么用中文在这发文章,你可以把中文翻译成英文在发表啊!
I am a chinese too, and there are some example, which use ipfs. The most popular example is a blog system. The github address is ipfs blog system I guess it will help you!
I am a chinese too, and there are some example, which use ipfs. The most popular example is a blog system. The github address is ipfs blog system7 I guess it will help you!
hello,you are so funny!
I just don’t understand, why were you repeate mine?
老哥这样不好吧,这是才外的社区。你懂的用中文不太好。
可以通过这个页面找到许多IPFS应用,还会持续更新:https://www.ipfsfirst.com/ipfsdaohang
You can find IPFS applications via this page and it will keep updateing: https://www.ipfsfirst.com/ipfsdaohang
现在节点也就800多点,我觉得最大的问题是没有好的基础设备。对最终用户还不够重视,目前主要还是在进行开发工作。对于一个普通人员,基本上没法用。起码在客户端上要达到BT的水平,更多的发展最终用户。
刚提了对路由器进行支持的建议,感觉路由器作为IPFS节点的承载设备比较理想。
感觉节点还是太少了,经常特别卡,而且同步的时候特别慢,特别是获得大文件的时候
It’s not just because of the amount of nodes, but also the decentralized DHT algorithms.
