Hello Team,
I have some questions related to IPFS swarm peers. It would be great if someone explain and give answer on my questions.
Here is the questions:
- I have run three cluster in local machine with docker compose, used this github docker-compose code.
Then I open IPFS webUI through localhost:5001/webui.
After that, there was so many peers shown in ipfs webui. (seems like swarm peers)
“If I add or publish files to my IPFS cluster, will these files replicate to other peer nodes that are shown in discovered peers?”
I don’t want to replicated my cluster file to those peers because it will be production data.
- What is difference between peers ls and swarm peers command? both give different output
peers ls shown only three cluster which is running in local env
swarm peers shown all public peers.
Thanks,
Mihir
