I have an ipfs gateway running on a kuberentes, all ports exposed and appendAddress has the ip and random port(4001) of the ipfs gateway node, usePubsub is true and on running ipfs name resolve & through ipfs.io i’m able to resolve IPNS hash.
But I have not been able to resolve IPNS hash through the gateway on port 8080.
I keep getting the error could not resolve name, Any clues on what might be causing this and how i can resolve the issue ?
ipfs config Addresses.API /ip4/0.0.0.0/tcp/5001
ipfs config Addresses.Gateway /ip4/0.0.0.0/tcp/8080
ipfs config Datastore.StorageMax 100GB
ipfs config Datastore.BloomFilterSize 1048576 --json
ipfs config Datastore.GCPeriod 12h
ipfs config Swarm.ConnMgr.HighWater 1000 --json
ipfs config Swarm.ConnMgr.GracePeriod 20s
ipfs config Swarm.ConnMgr.LowWater 250 --json
ipfs config Experimental.AcceleratedDHTClient true --json
ipfs config Gateway.NoFetch true --json
ipfs config Gateway.PublicGateways --json '{"dweb.link": { "NoDNSLink": false, "Paths": [ "/ipfs", "/ipns" ], "UseSubdomains": true }}'
ipfs config Ipns.ResolveCacheSize 512 --json
ipfs config Ipns.UsePubsub true --json
ipfs config Discovery.MDNS.Enabled false --json
ipfs config Addresses.AppendAnnounce --json '["/ip4/52.22.234.98/tcp/30001","/ip4/52.22.234.98/udp/30001/quic","/ip4/52.22.234.98/udp/30001/quic-v1","/ip4/52.22.234.98/udp/30001/quic-v1/webtransport"]'
ipfs config ResourceMgr --json '{ "Limits": { "System": { "ConnsInbound": 1024 } } }'
These are the settings I applied on my IPFS Gateway Node
So the config is
"API": {
"HTTPHeaders": {}
"Addresses": {
"Announce": [],
"AppendAnnounce": [
"/ip4/52.22.234.98/udp/30001/quic-v1/webtransport",
"/ip4/52.22.234.98/tcp/4001",
"/ip4/52.22.234.98/udp/4001/quic",
"/ip4/52.22.234.98/udp/4001/quic-v1",
"/ip4/52.22.234.98/udp/4001/quic-v1/webtransport"
"NoAnnounce": [
"/ip4/10.0.0.0/ipcidr/8",
"/ip4/100.64.0.0/ipcidr/10",
"/ip4/169.254.0.0/ipcidr/16",
"/ip4/172.16.0.0/ipcidr/12",
"/ip4/192.0.0.0/ipcidr/24",
"/ip4/192.0.2.0/ipcidr/24",
"/ip4/192.168.0.0/ipcidr/16",
"/ip4/198.18.0.0/ipcidr/15",
"/ip4/203.0.113.0/ipcidr/24",
"/ip4/240.0.0.0/ipcidr/4",
"/ip6/100::/ipcidr/64",
"/ip6/2001:2::/ipcidr/48",
"/ip6/2001:db8::/ipcidr/32",
"/ip6/fc00::/ipcidr/7",
"/ip6/fe80::/ipcidr/10"
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip4/0.0.0.0/udp/4001/quic",
"/ip6/::/udp/4001/quic",
"/ip6/::/udp/4001/quic-v1",
"AutoNAT": {},
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ"
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 1048576,
"GCPeriod": "12h",
"HashOnRead": false,
"Spec": {
"child": {
"path": "badgerds",
"syncWrites": false,
"truncate": true,
"type": "badgerds"
"prefix": "badger.datastore",
"type": "measure"
"StorageGCWatermark": 90,
"StorageMax": "100GB"
"Discovery": {
"MDNS": {
"Enabled": false
"Experimental": {
"AcceleratedDHTClient": true,
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"OptimisticProvide": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"NoDNSLink": false,
"NoFetch": true,
"PathPrefixes": [],
"PublicGateways": {
"dweb.link": {
"NoDNSLink": false,
"Paths": [
"/ipfs",
"/ipns"
"RootRedirect": ""
"Identity": {
"PeerID": "somepeeIddd",
"PrivKey": "CAESQPCWbxdbflolcRKlXoD4UGtEre3g/Xq+asdasdasdasdasdasd+RQ7C63Mb/BXU0aQJsdsXnNYMK7MVHZO6mRQS5g="
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 512,
"UsePubsub": true
"Migration": {
"DownloadSources": [],
"Keep": ""
"Mounts": {
"FuseAllowOther": true,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {},
"ResourceMgr": {
"Limits": {
"System": {
"Routing": {
"Methods": null,
"Routers": null
"Swarm": {
"AddrFilters": [
"ConnMgr": {
"GracePeriod": "20s",
"HighWater": 1000,
"LowWater": 250
"DisableNatPortMap": false,
"RelayClient": {},
"RelayService": {},
"ResourceMgr": {
"Limits": {}
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
