Hello,
i try to build a private swarm with Kubo containers (ipfs/kubo:latest), if I remove all bootstrapping peers and set the environment flag IPFS_SWARM_KEY_FILE with my key file I cannot get access to the web ui on http://localhost:5001/webui, the site is loaded but the browser hangs, so that the ui is not shown anymore. If I remove any “private” parts and let the container connect to the public peers everything works fine.
I have seen there is a post webui-not-working-in-private-network-configuration/6348, but in my case it should worked with the container version in a private network.
How can I make this work? Make it sense, to build my own container with pack the ui with the container?
I met this issue before. The reason here is when you try to open http://localhost:5001/webui, it will redirect to the link like this http://localhost:5001/ipfs/bafybeic4gops3d3lyrisqku37uio33nvt6fqxvkxihrwlqsuvf76yln4fm (if you are using Kubo v0.20.0) which is trying to load data from other peers. So if you’re in a private network, it won’t work.
Here is the solution:
- Start a public ipfs node, and let it download the WebUI files to your repo;
- Export the WebUI files as a car file by
ipfs dag export [webui root cid] > webui.car, which may take a while.
- After step 2 is finished, go to your private node, and import the car file by
ipfs dag import webui.car, it will unzip and save files to the node automatically.
Hope it can help you!
Thanks in general helps this, I create my own dockerfile and add the webui.car and initialize this with a shell script, so works for me with some little modification
Any chance you could share the dockerfile and shell script?
This is the shell script
00-ipfs-bootstrap-private.sh
574 B
#!/bin/sh -e
ipfs bootstrap rm all
#ipfs bootstrap add "/ip4/$PRIVATE_PEER_IP_ADDR/tcp/4001/ipfs/$PRIVATE_PEER_ID"
ipfs dag import /webui.car
ipfs config --json Experimental.FilestoreEnabled true
ipfs config --json Experimental.UrlstoreEnabled true
ipfs config --json Experimental.Libp2pStreamMounting true
ipfs config --json API.HTTPHeaders.Access-Control-Allow-Origin '["http://0.0.0.0:5001", "http://localhost:3000", "http://127.0.0.1:5001", "https://webui.ipfs.io"]'
ipfs config --json API.HTTPHeaders.Access-Control-Allow-Methods '["PUT", "POST", "GET", "DELETE"]'
and the Dockerfile
FROM ipfs/kubo:v0.21.0
# for private networks webui must be included manually,
# see https://discuss.ipfs.tech/t/kubo-container-with-private-swarm-webui-not-shown/16644
COPY ./webui.car /
COPY ./00-ipfs-bootstrap-private.sh /container-init.d
Thank you! That was very kind.
