Links to preview files don't work in webui?
I am running IPFS in a Docker container on a separate computer within my home network, and in setting the CORS headers settings to use the host computer’s local IP address of “192.168.0.100” and API configurations to use “0.0.0.0” (, I can get “http://192.168.0.100:5001/webui” to resolve properly from another computer on the network, but if I navigate into the “Files” section, and click on a JPEG that’s saved there, the UI shows a broken image because it’s trying to load “http://0.0.0.0:8080/ipfs/Qm…”. So it appears to be using the wrong IP address to try and fetch the image.
How can I configure this instance to not use “0.0.0.0” (the “use all IPs” config option), and not “localhost” but use “192.168.0.100”, the IP of the Docker host machine? If I put “/ip4/192.168.0.100/tcp/5001”, as the “API” config setting, then the webui doesn’t work at all (appears to be failing since “192.168.0.100” is not an IP address that the Docker Container can see?).
