Kubo v0.33.0-rc1 is out!
This Release Candidate ships right before the holiday break :slight_smile: and includes a ton of boxo / go-libp2p fixes and improvements ( AutoTLS , Bitswap, MFS, Flatfs and Datastore).
If you have spare time during holiday break, opt-in to AutoTLS and provide feedback:
$ ipfs config --json AutoTLS.Enabled true
See:
After a few minutes of working correctly, my node loses all incoming connections. I’ve tested it multiple times in a row. I’ve had to revert to 0.32.1
I’ll do further testing when I get a chance, and post a bug report
How’s it going since reverting back to 0.32.1?
Can you also share the output of cat ~/.ipfs/config | jq .Addresses.Swarm?
I haven’t had the time to explore it further (holidays and stuff), but reverting to 0.32.1 immediately fixed the problem. I’ll try it again in the next few days and post a proper bug report with config and everything. I was also hoping that others would begin to see the same behavior (it’s hard to believe I’m the only one, my configuration is pretty standard).
I have posted a proper bug report at:
