Kubo v0.36.0-rc1 is out!
This release aims to make Kubo more efficient, stable, and user-friendly for high-traffic retrieval operations.
Highlights:
- HTTP Retrieval Client is Enabled: Blocks now retrieved over HTTPS by default, if the provider supports trustless HTTP retrieval of blocks (
GET /ipfs/cid?format=raw
) - Reduced Bitswap Broadcasts: Dramatically cuts network traffic (up to 80-98%) and bandwidth (up to 50-95%), lowering operational costs and improving IPFS Mainnet stability long term.
- Smarter AutoNATv2/AutoTLS: Leads to fewer node startup errors due to improved NAT and public address detection.
- Enhanced File/Gateway: Includes
ipfs files cp
overwrite for files and negative HTTP Range request support for gateways. - Improved Filestore: Ability to manually remove bad blocks and heal
filestore
. - Configurable Connection Management: Exposes
ConnMgr.SilencePeriod
for finer control over libp2p connections.
For more details, see Release Notes: kubo/docs/changelogs/v0.36.md at release-v0.36.0 · ipfs/kubo · GitHub
Release Artifacts:
- Code: Release v0.36.0-rc1 · ipfs/kubo · GitHub
- Binaries: /ipns/dist.ipfs.tech/kubo/v0.36.0-rc1/
- Docker:
docker pull ipfs/kubo:v0.36.0-rc1
