Kubo v0.36.0 is out!
The release focuses on efficiency and stability improvements for high-traffic retrieval operations.
Highlights:
  • Reduced Bitswap traffic: 80-98% less network traffic and 50-95% bandwidth savings during high-load scenarios when retrieving many CIDs not available locally
  • HTTP retrieval enabled: Blocks now retrieved over HTTPS by default when providers support trustless HTTP (GET /ipfs/cid?format=raw)
  • Better connectivity: Enhanced AutoNATv2/AutoTLS reduces startup errors through improved NAT and public address detection
  • File operations: ipfs files cp overwrite support and negative HTTP Range requests for gateways
  • Filestore improvements: Manual bad block removal and filestore healing capabilities
  • Connection tuning: Configurable ConnMgr.SilencePeriod for libp2p connection management
This release particularly benefits operators running high-traffic nodes, public gateways, or infrastructure serving many concurrent requests. The bandwidth optimizations can substantially reduce hosting costs during traffic spikes.
Resources:
The release version for Intel Macs is not signed, making it completely unusable! Please see a similar bug I had reported 5 days ago about RC2 that still stands unnoticed!
Thank you for reporting, the macOS binaries for the final release should be now correctly signed.
(/ipfs/QmQENukvq1Njefjxn5mJNg4aUNXtLVG8UAtJpRMA42Ptfn/kubo/v0.36.0/)
All good now, thank you!
The Debian packaging pipeline runs automatically on Wednesdays and Saturdays, so the Ubuntu Launchpad package will come very soon!
