Kubo v0.38.2 is out!
The 0.38 release brings unified Provide config, experimental Sweeping DHT provider, better gateway errors, diagnostic tools, fixes, and more!
The 0.38.2 patch release improves retrieval, traces and memory usage, make sure to update ASAP to benefit from more providers.
- Release Notes: kubo/docs/changelogs/v0.38.md at master 路 ipfs/kubo 路 GitHub
- Release Tag: Release v0.38.2 路 ipfs/kubo 路 GitHub
- Binaries: /ipns/dist.ipfs.tech/kubo/v0.38.2/
- Docker:
docker pull ipfs/kubo:v0.38.2
Highlights
- Updates boxo v0.35.1 with bitswap and HTTP retrieval fixes:
- Fixed bitswap trace context not being passed to sessions, restoring observability for monitoring tools
- Kubo now fetches from HTTP gateways that return errors in legacy IPLD format, improving compatibility with older providers
- Better handling of rate-limited HTTP endpoints and clearer timeout error messages
- Updates go-libp2p-kad-dht v0.35.1 with memory optimizations for nodes using
Provide.DHT.SweepEnabled=true - Updates quic-go v0.55.0 to fix memory pooling where stream frames weren鈥檛 returned to the pool on cancellation
For full release notes of 0.38, see 0.38.1
