Kubo v0.38.0-rc2 is out!
RC2 includes fixes from RC1 testing. Main changes address common operational issues.
Notable fixes and improvements
Better handling of large content sets - If you’re announcing thousands of CIDs and running into issues, the experimental opt-in Sweeping DHT Provider (Provide.DHT.SweepEnabled) reduces memory and network usage significantly.
Gateway timeout diagnostics - 504 errors now include information about which providers were contacted and where retrieval failed, making debugging easier.
Updated WebUI (v4.9) - Added diagnostics screen for system monitoring and troubleshooting.
Simplified provider config - The required migration combines ProviderandReprovidersettings into a singleProvidesection.
Pin names now work correctly - ipfs pin ls <cid> --namesreturns the names you assigned to pins instead of empty results.
Testing
- Binaries: Release v0.38.0-rc2 · ipfs/kubo · GitHub
- Docker:
docker pull ipfs/kubo:v0.38.0-rc2 - Full details: kubo/docs/changelogs/v0.38.md at master · ipfs/kubo · GitHub
Please test and report any issues, particularly if you work with large pinsets or have experienced gateway timeout problems and struggled to debug before.
