Hello,
can anyone provide expert advice on moving huge KYC data on IPFS?
Thanks in advance
@jl1 the first things to address:
- What use cases are motivating you to put the data on IPFS?
- Is this public, open-access data that can be written onto IPFS in un-encrypted form, or is it private/sensitive data that would have to be encrypted before writing it to IPFS?
- Do you need to coordinate independent parties to pin the data on their nodes, or will you primarily pin the data on machines that you run?
Good questions and good answer.
