I have an interesting issue when working with Helia and Level Blockstore. When I re-initialize an instance of Helia with an existing blockstore the blockstore’s db is closed and the error Error: Database is not open is thrown.
Even if I complete delete the Blockstore’s directory the problem still occurs so I’m figuring something is floating around in memory.
I’m working with Mocha where each test run initializes helia during beforeEach and afterEach tears helia down:
Here is a simplified example of the problem I am experiencing in my beforeEach/afterEach initialization pattern:
import { createHelia } from 'helia'
import { LevelBlockstore } from 'blockstore-level'
import * as Block from 'multiformats/block'
import * as dagCbor from '@ipld/dag-cbor'
import { sha256 } from 'multiformats/hashes/sha2'
import { rimraf } from 'rimraf'
const main = async () => {
const createHeliaInstance = async () => {
let blockstore = new LevelBlockstore('./helia')
return createHelia({ blockstore })
const codec = dagCbor
const hasher = sha256
const block = await Block.encode({ value: 'hello world', codec, hasher })
// beforeEach
let helia = await createHeliaInstance()
// afterEach
await helia.stop()
await rimraf('./helia')
// beforeEach
try {
// afterEach
// this fails with "Database is not open"
await helia.blockstore.put(block.cid, 'hello world')
} catch (error) {
console.log('error', error)
} finally {
await helia.stop()
main()
The second Helia instantiation will result in a DB closed error when I try and put anything to helia.blockstore.
