I am going thought the documentation of libp2p and looking in how I can to use it the best for my project. I couldn’t find information about how the queries form the dht work (js version). There is no information in the spec nor in the the examples folder / the code.
So my question’s are:
- Is there a query language
- How should I use them
- When I send queries to a peer / list of peer’s, how do they process them?
- Can queries’s be used as an attac to produce a heavy work load on the network?
- If 4. is true, shouldn’t there be a way to blacklist those peer’s?
Thank you
