Manually subscribing to namesys-pubsub events
What I’m trying to do: piggyback on the namesys pubsub system to react to new ipfs name publish.
I’ve got two peers PeerA and PeerB with both pubsub and namesys-pubsub enabled:
ipfs daemon --enable-pubsub-experiment --enable-namesys-pubsub
I’m successfully doing this on PeerA:
ipfs add -r public/rngadam # last row has CID
ipfs name publish --key=$USER $CID
and I can list the content on PeerB.
What I’d like is also have PeerB reacts to the changes on my public key publishing.
I see that:
ipfs name pubsub subs
returns a list of subscriptions of type /ipns/$PUBLIC_KEY
but if I try to on PeerB to have:
ipfs pubsub sub /ipns/$PUBLIC_KEY
I don’'t get any events.
Is it doable? I’d rather not have to create a separate pubsub channel with artificial events on top of something that’s already happening behind the scenes.
I think it is doable but the channel might not be /ipns/$public_key (not sure). And the items that are broadcasted are probably binary protobufs.
do you know where I could look this up to understand how name uses pubsub? the content of the items broadcasted doesn’t really matter as long as I could use them as indication that something was published (without polling manually).
Actually, ipfs pubsub ls shows all topics to which pubsub is subscribed, including the IPNS ones.
ah right, so those prefixed with /record. Guess I can keep another ipfs pubsub sub on that whole list and reload on notification changes. Thanks!
