Kubo v0.21.0 is the first stable release of Kubo that supports the NOpfs plugin and vice-versa ![]()
This plugin parses content blocking lists in ~/.config/ipfs/denylists, effectively blocking the content from being retrieved/resolved by Kubo (and thus, provided on the gateways).
You can download the prebuilt binaries for v0.21.0 here. Installation consists in placing the plugin file in ~/.ipfs/plugins.
You can write your own denylist (example below) or grab the Protocol Labs-curated BadBits denylist..
You can add items to a denylist with something like:
echo "/ipfs/<cid>" >> ~/.config/ipfs/mylist.deny
No need to re-start your Kubo daemon. Any appended lines are picked up automatically.
Hereโs a simplified example of the syntax (more comprehensive example in the repo):
version: 1
description: A collection of bad things we have found in the universe
author: @myself
# Blocking by CID - blocks wrapped multihash.
# Does not block subpaths.
/ipfs/bafybeihvvulpp4evxj7x7armbqcyg6uezzuig6jp3lktpbovlqfkuqeuoq
# Block all subpaths
/ipfs/QmdWFA9FL52hx3j9EJZPQP1ZUH8Ygi5tLCX2cRDs6knSf8/*
# Block some subpaths (equivalent rules)
/ipfs/Qmah2YDTfrox4watLCr3YgKyBwvjq8FJZEFdWY6WtJ3Xt2/test*
# Block some subpaths with exceptions
/ipfs/QmUboz9UsQBDeS6Tug1U8jgoFkgYxyYood9NDyVURAY9pK/blocked*
!/ipfs/QmUboz9UsQBDeS6Tug1U8jgoFkgYxyYood9NDyVURAY9pK/blockednot
!/ipfs/QmUboz9UsQBDeS6Tug1U8jgoFkgYxyYood9NDyVURAY9pK/blocked/exceptions*
# Block IPNS domain name
/ipns/domain.example
# Block IPNS domain name and path
/ipns/domain2.example/path
# Block IPNS key - blocks wrapped multihash.
/ipns/k51qzi5uqu5dhmzyv3zac033i7rl9hkgczxyl81lwoukda2htteop7d3x0y1mf
# Double hash CID block
# base58btc-sha256-multihash(QmVTF1yEejXd9iMgoRTFDxBv7HAz9kuZcQNBzHrceuK9HR)
# Blocks bafybeidjwik6im54nrpfg7osdvmx7zojl5oaxqel5cmsz46iuelwf5acja
# and QmVTF1yEejXd9iMgoRTFDxBv7HAz9kuZcQNBzHrceuK9HR etc. by multihash
//QmX9dhRcQcKUw3Ws8485T5a9dtjrSCQaUAHnG4iK9i4ceM
# Double hash Path block using blake3 hashing
# base58btc-blake3-multihash(gW7Nhu4HrfDtphEivm3Z9NNE7gpdh5Tga8g6JNZc1S8E47/path)
# Blocks /ipfs/bafyb4ieqht3b2rssdmc7sjv2cy2gfdilxkfh7623nvndziyqnawkmo266a/path
# /ipfs/bafyb4ieqht3b2rssdmc7sjv2cy2gfdilxkfh7623nvndziyqnawkmo266a/path
# /ipfs/f01701e20903cf61d46521b05f926ba1634628d0bba8a7ffb5b6d5a3ca310682ca63b5ef0/path etc...
# But not /path2
//QmbK7LDv5NNBvYQzNfm2eED17SNLt1yNMapcUhSuNLgkqz
