From @RichardLitt on Thu Mar 10 2016 19:29:40 GMT+0000 (UTC)
Currently, we have some closed issues. I don’t think this is the right thing to do. All issues should be open, permanently.
I propose we unclose all issues, so it is easier to search. Issues that are 100% answered can be locked.
Copied from original issue: Open vs Closed Issues · Issue #99 · ipfs-inactive/faq · GitHub
From @RichardLitt on Thu Mar 10 2016 19:29:50 GMT+0000 (UTC)
Also, added a meta label.
From @lgierth on Tue Apr 05 2016 18:01:24 GMT+0000 (UTC)
Generally agree, but I think we should still close duplicates, just to avoid clutter
From @RichardLitt on Tue Apr 05 2016 21:55:55 GMT+0000 (UTC)
CC @diasdavid @whyrusleeping @noffle @haadcode @jbenet
From @diasdavid on Wed Apr 06 2016 01:43:03 GMT+0000 (UTC)
We should close duplicates and curate the content of the ones we keep.
From @noffle on Wed Apr 06 2016 06:13:59 GMT+0000 (UTC)
I agree with @diasdavid – remove dupes but maintain a high quality control on the ones that we do leave open. I think promoting organic questions to /proper FAQ questions and answers/ as we go is really important.
From @Kubuxu on Wed Apr 06 2016 08:57:11 GMT+0000 (UTC)
What do you think about deleting, moderating comments that are unclear out of topic for given issue (FAQ question)?
It might be controversial but if we want to keep high standard of the FAQ.
From @noffle on Wed Apr 06 2016 16:59:11 GMT+0000 (UTC)
@Kubuxu: if the question is poorly worded but not deduplicated, we could edit it to be more concise, and still provide a solid answer.
From @RichardLitt on Mon May 02 2016 19:44:31 GMT+0000 (UTC)
I added an ‘answered’ label. #112
Now I’ve gone through and put ‘answered’ on all of the issues I thought were pretty much done. Curating is really hard; but it is something we’ll need to do. Closing duplicates, badly worded questions, and pointing to well-done answers is something I think we should do organically as we go along. At some point, I should write a doc that goes through and makes good answers for questions, too; that will probably be what happens to the FAQ section on the website (still forthcoming).
Anyway, step in the right direction.
From @RichardLitt on Mon May 02 2016 19:55:58 GMT+0000 (UTC)
I’ve added a note to the Readme: check it out? Maybe then we can close this issue. https://github.com/ipfs/faq/pull/115
