Possible to use go-ipfs as a lib?
I am exploring the possibility of embedding go-ipfs in another application I have, where I programmatically create a node and programmatically perform tasks on that node…I looked briefly into the go-ipfs on github and it was not immediately clear if I can use it as a library instead of as a binary.
I also see no example on how to go about this. (Most or all examples are focused on running the go-ipfs binary instead)
Anyone has pointers on how to achieve my desire?
Link to go-ipfs-as-a-library example:
Also, depending on your requirements: https://github.com/hsanjuan/ipfs-lite
Thanks @hector
So I got around to start playing with this. I was able to follow the example and it works fine.
Now I am trying to see if I can run the node but with pubsub support enabled. I followed the link here https://github.com/ipfs/go-ipfs/tree/master/docs/examples/library-experimental-features but it seems there is no “pubsub” upon on the Experiment struct that can be enabled.
type Experiments struct {
	FilestoreEnabled     bool
	UrlstoreEnabled      bool
	ShardingEnabled      bool
	GraphsyncEnabled     bool
	Libp2pStreamMounting bool
	P2pHttpProxy         bool
	QUIC                 bool
	StrategicProviding   bool
or is there another means of getting PubSub enabled programmatically?
The Core node gives you access to a Pubsub: https://godoc.org/github.com/ipfs/go-ipfs/core#IpfsNode
Note that the example uses a default configuration: https://github.com/ipfs/go-ipfs/blob/master/docs/examples/go-ipfs-as-a-library/main.go#L56 and you may want to change things on that configuration before creating the node.
Thanks for the response @hector
This is exactly what I wanted to do. If you check the link I initially linked to https://github.com/ipfs/go-ipfs/tree/master/docs/examples/library-experimental-features, it shows how to change the configurations
// Create a config with default options and a 2048 bit key
	cfg, err := config.Init(ioutil.Discard, 2048)
	if err != nil {
		return "", err
// Here, configuration is being updated
	// https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md#ipfs-filestore
	cfg.Experimental.FilestoreEnabled = true
	// https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md#ipfs-urlstore
	cfg.Experimental.UrlstoreEnabled = true
	// https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md#directory-sharding--hamt
	cfg.Experimental.ShardingEnabled = true
	// https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md#ipfs-p2p
	cfg.Experimental.Libp2pStreamMounting = true
	// https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md#p2p-http-proxy
	cfg.Experimental.P2pHttpProxy = true
	// https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md#strategic-providing
	cfg.Experimental.StrategicProviding = true
But the problem now is, I do not see how to enable pubsub, using this pattern? Nothing like cfg.Experimental.PubSub = true is available. That is the part I am stranded at.
Right, but is the Pubsub field in core.IpfsNode nil?
I will check that out in a bit…
I confirmed it is nil
I had a break point somewhere around here and I confirmed it is nil.
There is a field in the config to enable it: https://godoc.org/github.com/ipfs/go-ipfs-config#PubsubConfig
