Hi, everybody
It’s been four days trying to get my own IPFS Desktop up and running and everything set up.
I uploaded the first folder of files (files max 1mb) 400pcs in total and everything went fine, within no time I had the files available via links.
Then I uploaded a second folder with 2 files (file max 1mb) but this folder is not accessible even after 3 hours.
I did not change the settings.
Connection stable.
I also tried IPNS, this is also not available.
The number of peers varies from 15~980
I tried resetting, disconnecting the network, reconfiguring, removing and re-adding the folder, changing the public gateway, pinning to the local node - nothing helped, no change, no error
The first folder is still accessible via links and everything works perfectly, fast, stable. But the second folder cannot be accessed.
I checked using the web and found that my only node provides the file, but it is not available on the public gateway.
Have I tried all the procedures here on the forum, or have I overlooked something.
Do you have any ideas on how to solve this?
