Hi All,
If you are using webrtc* as the transport, you need to have a hosted signal/rendezvous server if you plan to deploy the app in production.
Is there any way to make the pubsub between two remote peers work without a signal/rendezvous server?
I also read about circuit relay module, can this be used as a signalling mechanism for webrtc?
I’m not that familiar with js-libp2p but I believe you can just use circuit relay without signaling. If you know of a node willing to act as a relay, you can connect to the other node through the relay node and then use pubsub normally.
