Quation about IPFS Nginx Gateway
To make my own IPFS gateway.
I setup up IPFS (go-ipfs) and init it.
Then config nginx, proxy https(443) request to ipfs port 8080.
My page (“https://ipfs.mydomain.com/webui”, .e.g) has something wrong.
Html/JS content is ok,but api request is bad,because the url is http and port 443。 such as “http://ipfs.mydomain.com:443/api/v0/id?stream-channels=true”
What happen?
My Nginx Config:
    server {
            server_name ipfs.mydomain.com;
            listen 443 ssl;
            ssl on;
            ssl_certificate  /root/.ipfs/https_full_chain.pem;
            ssl_certificate_key /root/.ipfs/https_private.key;
            ssl_session_timeout 5m;
            ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE:ECDH:AES:HIGH:!NULL:!aNULL:!MD5:!ADH:!RC4;
            ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
            ssl_prefer_server_ciphers on;
            charset UTF-8;
            location / {
                  proxy_pass http://127.0.0.1:8080;
                  proxy_http_version 1.1;
                  proxy_set_header Host $host;
                  proxy_cache_bypass $http_upgrade;
The webui doesn’t run on the gateway, it runs on the API (different port). Am I missing something in your setup? If ipfs.mydomain.com proxies to localhost:8080 (the gateway), ipfs.mydomain.com/webui should give a 404.
However, assuming I am missing something in your setup, the following issue is likely relevant:
