dmellos
1
Hey there,
Is it possible to set basic authentication and configure ipfs gateway on https?
I was able to achieve it on ipfs-cluster API Endpoint 9094 using below
“restapi”: {
“ssl_cert_file”:"/var/tmp/server.crt",
“ssl_key_file”:"/var/tmp/server.key"
I want to know how to configure the same for gateway port 8080
hector
2
It’s not possible for the ipfs gateway. You need to put nginx or some other reverse proxy in front of it to do this.
@hector @dmellos on the same HTTPS-HTTP proxying task I encountered a very strange problem with Apache described here: Apache as HTTPS Reverse Proxy for IPFS Node: memory leak
Could you please have a look at this? I really need to find a way to resolve this… Sorry for spamming here, but I already created another question.
