Apache as HTTPS Reverse Proxy for IPFS Node: memory leak
I created the HTTPS proxy for IPFS node on my Apache server with the following settings:
Apache:
<VirtualHost *:443>
    SSLEngine on
    SSLProtocol all -SSLv2
    SSLHonorCipherOrder on
    SSLCipherSuite "ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS"
    Header add Strict-Transport-Security: "max-age=15768000;includeSubdomains"
    SSLCompression Off
    SSLCertificateFile /etc/letsencrypt/live/ipfs.mydoma.in/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/ipfs.mydoma.in/privkey.pem
    Include /etc/letsencrypt/options-ssl-apache.conf
    ServerName ipfs.mydoma.in
    ServerAdmin admin@ad.min
    ProxyRequests On
    ProxyPreserveHost On
    ProxyPass / http://localhost:48080/
    ProxyPassReverse / http://localhost:48080/
</VirtualHost>
IPFS (fragment):
"Addresses": {
    "Swarm": [
      "/ip4/*.*.*.*/tcp/45001"
    "Announce": [
	"/dns4/ipfs.mydoma.in/tcp/45001"
    "AppendAnnounce": [],
    "NoAnnounce": [
      "/ip4/10.0.0.0/ipcidr/8",
      "/ip4/100.64.0.0/ipcidr/10",
      "/ip4/169.254.0.0/ipcidr/16",
      "/ip4/172.16.0.0/ipcidr/12",
      "/ip4/192.0.0.0/ipcidr/24",
      "/ip4/192.0.2.0/ipcidr/24",
      "/ip4/192.168.0.0/ipcidr/16",
      "/ip4/198.18.0.0/ipcidr/15",
      "/ip4/203.0.113.0/ipcidr/24",
      "/ip4/240.0.0.0/ipcidr/4",
      "/ip6/100::/ipcidr/64",
      "/ip6/2001:2::/ipcidr/48",
      "/ip6/2001:db8::/ipcidr/32",
      "/ip6/fc00::/ipcidr/7",
      "/ip6/fe80::/ipcidr/10"
    "API": "/ip4/127.0.0.1/tcp/65001",
    "Gateway": "/ip4/127.0.0.1/tcp/48080"
The problem is that running daemon starts immediately to hang up many opened connections on Apache, and to consume a lot of memory spamming the log with the message:
2022-02-13T14:38:45.172+0300	INFO	bs:sess	session/session.go:459	No peers - broadcasting	{"session": 45, "want-count": 1}
This process consumes about 3GiB of memory when session value reaches ~1000.
The process works normally when proxying is disabled.
I tried to implement a lot of samples of HTTP proxying for IPFS, nothing works. Please help me to clarify the keystone of this situation. What could be a reason for such behaviour? How to set up Apache HTTPS-HTTP proxy for IPFS node properly?
Perhaps you are affected by 51814 – mod_proxy in Apache HTTP 2.2 FIN_WAIT2 in server side, it leaves as CLOSE_WAIT for a long time in mod_proxy side. ? (see apache 2.2 - Apache2 reverse proxy connections staying persistent, filling ssh channels - Server Fault)
In principle, the bitswap messages you see are not related to the reverse proxy connections not being closed though.
We run our reverse proxies with nginx and it works fine btw.
Thanks, @hector ! These messages, however, I used as an indication point if the problem is present, and they indicate. It seems the migration to Nginx is becoming necessary in the old project to start involving IPFS…
