Hi everyone. So I’m trying to finish setting up my Public Gateway. I’m having a small problem that is causing a couple issues I need resolved. So I "m trying to add the below to my config file. When I restart IPFS with the below it will not start. When I remove this it works fine but I cannot get the subdomain features to work because of it. I’m using go-ipfs 11.
"PublicGateways": {
"gateway.mydomain.com":{
"Paths": ["/ipfs", "/ipns"],
"UseSubdomains": true
