Hi
In my case I have ipfs nodes in the node environment and I can’t get them to connect, i can’t see the hash id of the other nodes in my peers, how can i discover them? it’s supposed to be able to get discovered in node environment right without use of w*-star?..
setInterval(async()=>{
let peers = await ipfs.swarm.peers()
peers.forEach((e)=>{
console.log(e.peer)
}, 5000)
I would suppose that by bootstrapping I should find my nodes on the network?
DHT random walk, pubsub?
relay: {
enabled: true,
hop: {
enabled: true,
active: true
pubsub: {
enabled: true,
emitSelf: true
dht: {
kBucketSize: 20,
enabled: true,
randomWalk: {
enabled: true,
interval: 300e3,
timeout: 10e3
Default Bootstrap
'/ip4/104.236.176.52/tcp/4001/p2p/QmSoLnSGccFuZQJzRadHn95W2CrSFmZuTdDWP8HXaHca9z',
'/ip4/104.131.131.82/tcp/4001/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ',
'/ip4/104.236.179.241/tcp/4001/p2p/QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM',
'/ip4/162.243.248.213/tcp/4001/p2p/QmSoLueR4xBeUbY9WZ9xGUUxunbKWcrNFTDAadQJmocnWm',
'/ip4/128.199.219.111/tcp/4001/p2p/QmSoLSafTMBsPKadTEgaXctDQVcqN88CNLHXMkTNwMKPnu',
'/ip4/104.236.76.40/tcp/4001/p2p/QmSoLV4Bbm51jM9C4gDYZQ9Cy3U6aXMJDAbzgu2fzaDs64',
'/ip4/178.62.158.247/tcp/4001/p2p/QmSoLer265NRgSp2LA3dPaeykiS1J6DifTC88f5uVQKNAd',
'/ip4/178.62.61.185/tcp/4001/p2p/QmSoLMeWqB7YGVLJN3pNLQpmmEk35v6wYtsMGLzSr5QBU3',
'/ip4/104.236.151.122/tcp/4001/p2p/QmSoLju6m7xTh3DuokvT3886QRYqxAzb1kShaanJgW36yx',
'/ip6/2604:a880:1:20::1f9:9001/tcp/4001/p2p/QmSoLnSGccFuZQJzRadHn95W2CrSFmZuTdDWP8HXaHca9z',
'/ip6/2604:a880:1:20::203:d001/tcp/4001/p2p/QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM',
'/ip6/2604:a880:0:1010::23:d001/tcp/4001/p2p/QmSoLueR4xBeUbY9WZ9xGUUxunbKWcrNFTDAadQJmocnWm',
'/ip6/2400:6180:0:d0::151:6001/tcp/4001/p2p/QmSoLSafTMBsPKadTEgaXctDQVcqN88CNLHXMkTNwMKPnu',
'/ip6/2604:a880:800:10::4a:5001/tcp/4001/p2p/QmSoLV4Bbm51jM9C4gDYZQ9Cy3U6aXMJDAbzgu2fzaDs64',
'/ip6/2a03:b0c0:0:1010::23:1001/tcp/4001/p2p/QmSoLer265NRgSp2LA3dPaeykiS1J6DifTC88f5uVQKNAd',
'/ip6/2a03:b0c0:1:d0::e7:1/tcp/4001/p2p/QmSoLMeWqB7YGVLJN3pNLQpmmEk35v6wYtsMGLzSr5QBU3',
'/ip6/2604:a880:1:20::1d9:6001/tcp/4001/p2p/QmSoLju6m7xTh3DuokvT3886QRYqxAzb1kShaanJgW36yx',
'/dns4/node0.preload.ipfs.io/tcp/443/wss/p2p/QmZMxNdpMkewiVZLMRxaNxUeZpDUb34pWjZ1kZvsd16Zic',
'/dns4/node1.preload.ipfs.io/tcp/443/wss/p2p/Qmbut9Ywz9YEDrz8ySBSgWyJk41Uvm2QJPhwDJzJyGFsD6',
'/dns4/node2.preload.ipfs.io/tcp/443/wss/p2p/QmV7gnbW5VTcJ3oyM2Xk1rdFBJ3kTkvxc87UFGsun29STS',
'/dns4/node3.preload.ipfs.io/tcp/443/wss/p2p/QmY7JB6MQXhxHvq7dBDh4HpbH29v4yE9JRadAVpndvzySN'
