hi site admins and DNS admins,
i’d like to notify you about a misconfigured DNS record which causes registration and other system emails do NOT get delivered. could you please reach out whoever responsible for emailing and dns config to fix it?
i was about to register on discuss.ipfs.io
, but the verification email comes from discoursemail.com
does not get accepted because of invalid SPF record.
here is what SPF validators says:
Invalid SPF Policy
The policy contains one or more syntax errors.
Invalid term “2602:fd3f:0000:ff06::/64”: name must not begin with a non-alpha character.
Results - PermError SPF Permanent Error: Unknown mechanism found: 2602:fd3f:0000:ff06::/64
Return to SPF checking tool (clears form)
Context: Failed to query MAIL-FROM
ErrorCode: (2) Could not find a valid SPF record
Error: Invalid character at start of mechanism near ‘2602:fd3f:00’
Error: Failed to compile SPF record for ‘discoursemail.com
could you please fix it?
it’s just simply “ip6:” prefix is missing at the front of the last ipv6 range.
thanks.
andreas
