Hello,
I have a problem with IPFS throughput. In my VPN, two remote computers exchanging files, no more than 30 mbps. In the Speedtest is 100 mbps.
Are there any transfer rate limitations on ipfs?
Hello,
You mean a speedtest between the two computers? Or a speedtest online tool? If the latter, 30mbps seems ok. What is the raw speed you can get (you can test with tools like iperf3) on the connection?
Also, make sure you are on IPFS 0.8.0.
