We are setting up our IPFS private network
  1. We have one bootstrap node on aws
  2. Two computers on the same LAN and one public computer
  3. All (4 nodes) share the same swarm.key and disabled firewall
  4. 3 nodes directly connect to bootstrap node
Our problem is
Two/all nodes LAN can see each others BUT all peers in public cannot see each others (ipfs ping, ipfs swarm connect)
So is it IPFS limitation or our setup problem? Please help us
It’s most likely a network issue. You’ll need to make sure the nodes are reachable on port 9096
