From @RichardLitt on Fri Oct 09 2015 18:11:45 GMT+0000 (UTC)
There are two repositories in the ipfs organization: node-ipfs-api and ipfs-api. What’s the difference between the two? Are they interchangeable? If one is a node implementation and the other a node digester, will node-ipfs-api eventually use node-ipfs?
Copied from original issue: https://github.com/ipfs/faq/issues/60
From @whyrusleeping on Fri Oct 09 2015 18:13:25 GMT+0000 (UTC)
the node-ipfs-api is api bindings for the ipfs api written in node.
node-ipfs is the actual node.js implementation of the ipfs protocol
From @VictorBjelkholm on Fri Oct 23 2015 15:46:42 GMT+0000 (UTC)
I’m thinking if the repos should change name to JS to reflect the scope. Focus seems to be on node+browser and then it’s really javascript, not just node.
From @jbenet on Fri Oct 23 2015 17:42:20 GMT+0000 (UTC)
good points. it would also help to ease confusion to call all the things
“js-” instead of “node-” as “node” has many meanings in IPFS land.
On Fri, Oct 23, 2015 at 8:46 AM, ᴠɪᴄᴛᴏʀ ʙᴊᴇʟᴋʜᴏʟᴍ notifications@github.com
node.—
Reply to this email directly or view it on GitHub
https://github.com/ipfs/faq/issues/60#issuecomment-150612981.
From @RichardLitt on Mon May 02 2016 19:25:31 GMT+0000 (UTC)
These are all called js- now.
