Suppose, I have running gateway at domain https://ipfs.example.com
This works fine when I use is as gateway. But I want to change the content served at this root domain viz. /. How to change that content. Where is that folder?
Currently, this root domain gives 400 error
There’s a RootRedirect option in the configuration (go-ipfs/config.md at master · ipfs/go-ipfs · GitHub).
But what I do is to run nginx in front and serve /
directly without involving the gateway.
What will be the content inside " "
at RootRedirect? Is it just local folder address or localhost fqdn?
Btw, nginx setting on '/'
path is not working and giving 500 error for valid gateway urls too.
@lidel plz help. Official documentation has no further guidance there.
