Why does the ipfs gateway return errror code 410 Gone (openresty)
Maybe this public gateway has a rate limit, you can choose another public gateway: Public Gateway Checker | IPFS
Such as cf-ipfs.com.
It is still the same thing;
Can you please help with some other option to host HTML file just like ipfs; please
I’m not sure what file sharing programs support “public gateways”.
I did a search on what “410” means and it seems that your file is not available to the gateway, meaning you may not be on the IPFS network?
I don’t understand the quote there
I have the same gone error on old URL which worked in the past
example: https://gateway.ipfs.io/ipfs/zdj7Whp8MXSDAgmwiv8f7UBseBzjYfTXiNm7Nk9m4GpZzoHCW
Is it due to the new Kubo version ?
