window.IpfsHttpClient is not a function
const ipfs = window.IpfsHttpClient({ host: ‘ipfs.infura.io’, port: ‘5001’, protocol: ‘https’ });
i was using above code to connect to ipfs using ipfs-http-client but its not working anymore with the latest or previous version of ipfs-http-client.
am i doing something wrong !?
How did you include the ipfs-http-client library?
its was cdn base injection and it was fully working like 2 months ago with this call :
but after trying with
const ipfs = window.IpfsHttpClient.create({ host: ‘ipfs.infura.io’, port: ‘5001’, protocol: ‘https’ });
its working now :expressionless: , it was quite strange because it was not the part of the cdn base constructor call based on the documentation, anyway its working now and thank you for your response
Thank you. I had this same issue. but window.IpfsHttpClient.create worked
