Best way to build a serverless room using WebRTC?
Hello,
I’m studying IPFS.
Can I use it for create a node using a generated hash for creating a virtual room where to chat?
I’m seeing the example code for a WebRTC chat: GitHub - cjb/serverless-webrtc: A demo of using WebRTC with no signaling server.
But I admit it: for me at first glance is not really clear.
Can I create an hash as a reference for creating a WebRTC chat, wherefrom this hash you can take the rtc addresses of online users?
Yes, there are probably more direct solutions to get the same result but I’m just a noob about this.
My intent, to be honest, is not create a chat, but a dynamic directory where can I divide the content, for example, for the initial letters for distributing the content. But basically, I would understand if I can use ipfs for making it totally serverless and at the same time use it for retrieving RTC addresses of active peers.
Thank you!
Update:
I just found this article: https://docs.ipfs.io/how-to/create-simple-chat-app/#peer-discovery-and-connectivity
Practically the repo is the way to set the “domain” of a “room”?
