Can't fetch any external cid from docker container (halting)
So I’m running this ipfs docker container
following the instructions in the README and then trying to execute some commands
but when I try fetching an external cid that doesn’t live on my local node like below
ipfs files stat /ipfs/QmbWqxBEKC3P8tqsKc98xmWNzrzDtRLMiMPL8wBuTGsMnR --api /ip4/127.0.0.1/tcp/5001/
it’s hangs and never resolves. If I use the same command for any local cids on my node it executes quickly. Do I have to open a port or is it just inevitable and external cids take more time
