Hi *,
I worked today on the chat-with-rendezvous of go-libp2p-examples. I would like to share my experiences and problems.
At first, I struggled a bit with the
importhaving the IPFS references from more than onemake installexecutions (ipfs, libp2p, …). Finally, I removed all and installed IPFS only
BTW:-does split the import path as well and the appropriate word can be used in the code. -
For clarity and to loop over all peers to write to, I used two slices, one for read and one for write.
The part of the code which executes
kadDht.FindProviders, loops over the returned peers, and opening new streams for writing was moved into an endless loop inside a goroutine. The already existing peers and write connections, respectively, were ignored. -
The prompt was changed so that the sender is shown.
The default
rendezvousStringwas replaced by a UUID
Finally, it was close to a real chat
e.g. my last test with nine running chats:
Having a fresh UUID and after some time (~3min) all nine chats, I had started, can send messages and seven do receive from all other. So two chats had lost nearly all of their read connections.
Here the problems or challenges:
Although, the
hosthas[]ma.Multiaddrand thekadDht.Providewas successfull, thekadDht.FindProvidersreturns the appropriate peer without addresses (Issue #23) -
If the chat is killed, new chats show errors related to the old peers, which are still returned from
kadDht.FindProvidersbut can not be found anymore (Issue #24).
I hope, if I spread into the internet and start the chats not only on my laptop locally, it still works, or I will be able to fix it.
Tomorrow, I plan to refactor the code and make it presentable.
Comments or tips are appreciated.
Cheers, Stefan
