Composite Clusters
The IPFS Proxy has been tested by me. And with the IPFS Proxy, I can already operate the IPFS-cluster.
However, A cluster of clusters has not been successfully built.
So I want to ask, how did the main cluster and sub-clusters communicate? What is the configuration details?
You need to set the node_multiaddress of the “overcluster” peers to the proxy endpoint of the subclusters. So that a peer from the main cluster would use another pear from a subcluster instead of the ipfs daemon.
Thank you very much,I have set it up successfully.
Let us know of your experience. We haven’t tested composite clusters much.
