Content was not loading, now its loading
Hi There,
On Friday 24th Dec, we were not able to load content from IPFS https://ipfs.io/ipfs/QmYym
There was more files had same issue like this.
Same files started loading from yesterday automatically. We didn’t did anything to make it working. We tried accessing these files from multiple region like USA, Asia etc
what could be possible problem?
Thank you
We don’t know, if you share the CID I might check.
Thank you @Jorropo for quick response.
here is CID QmYymZqpzZfTHPrdZCAGWU95KuXHNSZ5dGPwuUQqskJULy
Thank you
So I’ve run:
$ ipfs dht findprovs QmYymZqpzZfTHPrdZCAGWU95KuXHNSZ5dGPwuUQqskJULy
And there are not nodes returned.
So this mean that nodes hosting that file doesn’t advertise on the DHT.
You can only download that file if you happen to bump into the hosting node by luck in the sea of 11k public nodes of the IPFS network.
If I run that:
$ vole bitswap check QmYymZqpzZfTHPrdZCAGWU95KuXHNSZ5dGPwuUQqskJULy /dnsaddr/fra1-1.hostnodes.pinata.cloud/p2p/QmWaik1eJcGHq1ybTWe7sezRfqKNcDRNkeBaLnGwQJz1Cj | jq .
  "Found": false,
  "Responded": true,
  "Error": null
So I’ve basically just asked pinata’s node “do you have that file ?” and they respond with yes.
TLDR
This file is hosted by pinata, pinata doesn’t use the DHT (note the DHT is a mesh of nodes that allows to find where content is).
You can use a pinning service that use the DHT instead like https://fleek.co/, https://web3.storage/ or https://nft.storage/.
Maybe see this: Peering with content providers | IPFS Docs also
Thank you @Jorropo for details. this give us good direction to find root cause of issue.
