Curated list of IPFS gateways
I hope to have a 100mbit dedicated public gateway setup in the next few weeks. Once that happens, I will reply with details.
Updated for pull request, but moved to the following repo due to size: https://github.com/JayBrown/Tools/tree/master/ipfg
CLI has been updated to v1.2.1: https://github.com/JayBrown/Tools/tree/master/ipfg
Now includes option -u | --upload | --cache to cache an IPFS object from your local node or a remote node on a public gateway.
You can check gateway list from here https://github.com/VanVan/ipfsProxyHTTP
I’ve added a couple of URLs via pull request:
http://gateway.ipfs.so
At some point FileNation will also be running its own gateway.
http://cloudflare-ipfs.com/
The eternum.io gateway has moved to ipfs.eternum.io.
(context)
https://gateway.pinata.cloud
https://nuts.rtradetechnologies.com:6772/ipfs
https://nuts.rtradetechnologies.com:6772/ipns
Just got these online earlier this week, they will be refined as time goes on. Attempting to browse anything other than /ipfs/... and /ipns/... will redirect to google.
https://ipfs.mle.party
https://ipfs.lol/
+1
http://gateway.bdaily.club
I used to use these gateways quite a bit, is there any reason they might be acting slow?
For context: I’m working on a machine learning algorithm that opens a random port, and then using localtunnel to make it a temporary public URL. Since I’m having trouble reinstalling localtunnel, I thought I might try rewriting the code to use IPFS instead.
