I just deployed a Kubo node to fly.io using the official Docker image, and now I’ve run into a problem with the node not advertising its public IP.
When I ssh into the deployed container and run ipfs id, I get:
"ID": "12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"PublicKey": "CAESINJd0d4A1uiarVU0g+r+qYhv1i7Y2m9zrQ/AnD3NIm2q",
"Addresses": [
"/ip4/115.196.7.234/tcp/4001/p2p/12D3KooWJecc1MsmYT2sp2iS1KvNLQ187h8g6uQbniN8ghoEQzmp/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip4/127.0.0.1/tcp/4001/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip4/127.0.0.1/udp/4001/quic/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip4/172.105.192.229/tcp/4001/p2p/12D3KooWD6ejSQDKsGYCXw2EBByj3WJJmgbqub5csdXFE5GqwJ5D/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip4/172.105.192.229/udp/4001/quic/p2p/12D3KooWD6ejSQDKsGYCXw2EBByj3WJJmgbqub5csdXFE5GqwJ5D/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/240e:390:434:84f1:5062:5af3:ba50:2860/tcp/4001/p2p/12D3KooWJecc1MsmYT2sp2iS1KvNLQ187h8g6uQbniN8ghoEQzmp/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/240e:390:434:84f1:a130:508:158:d6cc/tcp/4001/p2p/12D3KooWJecc1MsmYT2sp2iS1KvNLQ187h8g6uQbniN8ghoEQzmp/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/240e:390:434:84f1:a491:babc:7308:bf0/tcp/4001/p2p/12D3KooWJecc1MsmYT2sp2iS1KvNLQ187h8g6uQbniN8ghoEQzmp/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/240e:390:434:84f1:f802:b338:cce0:bc18/tcp/4001/p2p/12D3KooWJecc1MsmYT2sp2iS1KvNLQ187h8g6uQbniN8ghoEQzmp/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/64:ff9b::ac69:c0e5/tcp/4001/p2p/12D3KooWD6ejSQDKsGYCXw2EBByj3WJJmgbqub5csdXFE5GqwJ5D/p2p-circuit/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/::1/tcp/4001/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru",
"/ip6/::1/udp/4001/quic/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru"
"AgentVersion": "kubo/0.15.0/3ae52a4/docker",
"Protocols": [
"/ipfs/bitswap",
"/ipfs/bitswap/1.0.0",
"/ipfs/bitswap/1.1.0",
"/ipfs/bitswap/1.2.0",
"/ipfs/id/1.0.0",
"/ipfs/id/push/1.0.0",
"/ipfs/lan/kad/1.0.0",
"/ipfs/ping/1.0.0",
"/libp2p/autonat/1.0.0",
"/libp2p/circuit/relay/0.1.0",
"/libp2p/dcutr",
"/p2p/id/delta/1.0.0",
"/x/"
Since the container isn’t aware of the public IP, it isn’t showing up.
I tried to add it manually with the following configuration:
ipfs config Addresses.Announce --json '["/ip4/137.66.16.155/tcp/4001"]' However, even after setting this, kubo doesn’t seem to be aware of this public IP.
I tried looking up the peer records from another IPFS node and got the following:
ipfs dht findpeer 12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru
/ip6/::1/tcp/4001
This indicates that the public IP (non circuit relay addresses) isn’t advertised.
To make sure that it’s actually possible to connect to the node, I ran:
ipfs swarm connect /ip4/137.66.16.155/tcp/4001/p2p/12D3KooWPyYm32rgQwU5vtip42ASH6tkSSLfPo1gnYMkkZyjxaru
Which worked successfully.
How can I make sure that the node advertises the hard-coded public IP set in Addresses.Announce? I also tried Addresses.AppendAnnounce which didn’t work
